Wiper rest position - why?
Originally Posted by ed devinney
Check the archives - to get the wipers to fully park on the other side you need to make a mechanical adjustment. Small hands help.
Parking the wipers on the passenger side allows you to have a longer wiper blade for the driver side !
I did the mechanical swap years ago and run a 18inch wiper for the driver side.
Guess if you dont use the reason for the swap, its a waste of time !! I would never go back to the old way.
Just for history the 911 had the wipers parked on the passenger side at first.
Read all kinds of BS about clearing the screen faster but no real explanation !
Geoff
Geoff
mbb 993 I also was going to do the mechanical switch but after scraping my knuckles decided not to ! I recently did the relay trick. It is a ten minute job. Do a search for specifics but in a nutshell pull intermittent fuse park wipers to passenger side. switch both wiper arms as one is longer and should be seated nearer to the bonnet and position them as low as possible . -paul
There is an easy way to reverse the wipers. You have to give up the intermittent function. Remove wiper relay R42 from inside the front trunk. Use the wiper lever to manually leave the wipers as far as they will go to the right. From the outside of the car, you can then remove and reposition the blades as low as you'd like. Switch the wipers with each other while you're at it, the one that was on top goes on bottom, the one that was on bottom goes on top. This makes a huge difference from the driver's perspective.
Happy (clear vision) Driving,
Mark
Mark
Wow, that was easy and quick. 10 minutes and didn't even need to fix anything else after I was done! I am glad I saw this post because I was procrastinating about the knuckle busting DIY I was planning to do and this is quickly reversible. I rarely need them. That will likely be the easiest "mod" I will ever do to my P-car!
Originally Posted by David in LA
Yes I've read the procedure, but rather than a mechanical change is it possible to just swap the control units or will this have no effect? I have access to a U.S. left hand drive and a Euro right hand drive cars so I could just swap them.
MB - if you don't use the wipers a lot you can slightly loosen the tension on the blade retaining nuts and nestle them down lower on the passenger side. They won't go down as far on the driver's side but they'll look better parked.
I didn't know about the relay trick, fantastic. The wipers do sit high on the passenger side, but that doesn't bother me in the slightest. Losing the intermittent function is a minor annoyance, now all we need is someone to design a relay that brings back the intermittent function, without losing the ability to 'park' the wipers.
I brought this subject up because I spent a couple of hours driving in rain the other day and I just loved the brief glimpses of front wing and bonnet while the wipers were on. I also love that you get a good view of spray kicked up by my car because the rear window stays clear of water at speed, unlike most cars I've driven in the past.
I'm 99% sure that the park position is built into the motor, hence the need to swap the linkage over to stop 180 degrees out. PET shows two different motors and crank units (LL and RL) but only one wiper interval relay....
Yeah - adjusting the height once they park is easy... just loosen the top bolt on the wiper arm shaft, move it down as low as you want without hitting the paint or trim, then retighten.
