Front Strut Replacement
this past monday i hit a pot hole (imagine that in downtown houston) and blew out the front strut on the drivers side. Quote for replacing both front strutswith monroe shocks was ~$1200, bilstein was a couple hundred more.
questions for you guys is:
1) where can i get the bilstein stuts for the best price?
2) is it reasonable for me to change the struts? If so, any DIY recommended?
thanks for all your help.
http://forums.rennlist.com/rennforu...ad.php?t=258810 .
Good Luck!
https://rennlist.com/forums/993-forum/258810-diy-suspension-install-for-dummies.html
OF COURSE it is reasonable to do it yourself. You will need a professional alignment afterward, no matter what. But, it really isn't that hard.
Your DIY explanation is just brilliant. I'm going to have a go when the goodies arrive. You make it look so easy.
Cheers
will you talk to me a bit more about the ROW suspension vs the americana version ... want to know pro's/ con's and how much it will cost ... one con i can think of is bottoming out with the roads in houston
also keep in mind my 911 is a daily driver not a showroom piece, alternate between my zx-9 and the porsche for commuting to work
muchas gracias
vbmotorsports@gmail.com
Bob: 650-743-6801
He will tell you everything you need to know and has the best prices.
Mike
muchas gracias
" Which, by the way, is probably what you will do after you thoroughly research the subject.In short,
MO30 springs are progressive rate springs compared to the stock linear rate springs. In a nutshell, the MO30 will ride just a tad more rigid than the stock springs when going down the highway, but will be infinitely better as they load up in the corners (i.e. as they load up, the spring rate increases).
The MO30s come in both ROW version and USA. The USA are longer to provide the much maligned SUV ride height. The choice is yours--but we will strip you of your Rennlist Membership if you choose unwisely.
You will not "bottom out" as long as you don't push the envelope on lowering the car. I lowered my car to just above the Porsche 993RS ride height, which is the lowest of the Porsche specified street heights. Although many like the look and feel of the RS ride height, you can set yours a bit higher at the ROW Sport setting. I can pretty much gaurantee that you won't have any problems at this height unless you go off road or even your potholes in Texas are big. (Michigan roads are one of the worst in the nation and I fared fine near RS height).
Well, ... gotta go, but let us know if you have any other specific questions.
