I am considering, based on several responses, changing out the suspension in the 993. It is bone stock now. ALL have said go the ROW/Billstein route. Are there any other choices? Not that I don't want to BUT there are many other spring and supension vendors i.e. Koni which I have used for my M3's.
Go the ROW/Bilstein route. Other springs choices are H&R (a little stiff) and Eibach (reportedly don't last too long-begin to sag). And you won't find a better shock absorber for our cars than Bilstein HD's.
chuck
Before we can answer the question, you need to tell us what car you have (coupe/cab) and how you intend to drive it (daily driver, autocross, DE, track). The answers to these questions will change the recommendation.
As RallyJon might (or might not) know, there are no Konis that fit 993's anymore AFAIK. So that's not an option. Eibachs aren't considered good choices AFAIK because they lower your car with about the same spring rates, so there's not a good shock choice. Don't forget that Porsche 993's are not subarus; there really aren't many choices for a lot of our mods.
So Jukelemon, I think you already have your answer.
I like the PSS9's but only went with them because the cost difference versus just adding Bilstein HD's to my RoW springs seemed reasonable for the added flexibility of a coil-over system. I've heard of 911/930 turbos from the mid 1980's still running their original Bilsteins and understand that they can be removed and refreshed for alot less than new shocks. I'd go Bilsteins and RoW springs if you are trying for good quality but a slightly less pricey set-up than the PSS9's.
p.s. the new owner of my RoW springs said he's going to get Bilstein HD's when he does the install if thats any indication of what people like around here.
Jukelmon,
I have the ROW M030 shocks and springs (recently replaced) if you want to see how it feels. Based on my experience with my previous 993 with Bilstein HDs they are very similar. But I would do the Bilsteins due to the longevity of them over the stock shocks.
I have just insalled the bilstein hd shocks with eibach springs. I am very happy with this setup and it is a huge improvement both in ride quality and control over the stock setup.
I did measure the eibachs before installation. The static stack height was about the same and I found that the diameter of the wire and the coils were similar to M030 USA springs ... the number of turns and pitch was different so I don't think the spring rates were the same as the factory springs. Didn't know that eibach was the subject of negative feedback. Are there any other happy eibach users out there that care to report??
Why is that surprising? Which Konis would you suggest for a 993? Part numbers please.
It is surprising sir because Koni makes a very good shock AND it is the preferred shock for BMW upgrades. My assumption would then be Koni would be in this market as well. Bad assumption as indicated by the info on Koni no longer making shocks for the 993.
Jukelmon,
Greg:
I know a greg Fishman, Transy grad. That is not you is it?
