993 Forum 1995-1998
Springs and shock choices
Old 02-07-2007, 09:08 PM
  #31
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
TJ-- go with either ROW M030 springs or H&R -- many reports of Eibach springs sagging despite their warranty - FYI
Old 02-07-2007, 11:26 PM
  #32
tj90
tj90's Avatar
I presume you test this my measuring spring height once they are out of the car and compare them to new?
Old 02-08-2007, 01:02 PM
  #33
Jukelemon
Jukelemon's Avatar
Another VERY important thing to consider is that there are m030 USA and ROW versions. I assume that most throw around the m030 tag and assume folks know that it is the ROW. But I didn't and thankfully worked through the differences with Mike prior to buying the m030 ROW springs. I saw an internet posting that clearly showed the differences between the two and they were significant.
Just a quick throw in here for those that are trying to wrap their heads around change possibilities AND those, like me, that sought lightly used springs as opposed to going with new ones.
Juke
Old 02-08-2007, 01:12 PM
  #34
tj90
tj90's Avatar
What are the differences between the 2 springs? The M030 front shocks are the same everywhere...
Old 02-08-2007, 01:39 PM
  #35
Wilder
Wilder's Avatar
Received 5,007 Likes on 1,776 Posts
Juke
There was a recent post that discussed two or three spring rates for the ROW M030. I've also got a 95 cab and bought my HD/M030s before I saw that thread. As it turns out, I bought the stiffer springs (which I belive are for turbos) which is not a bad option given that the cabs are a little heavier in the back but I still notice slightly more stiffness in the back vs the front (IIRC the fronts are all the same). Do a search and figure out what works for you.
As far as the options available, I also drive aggressively and the HDs do a great job. I do AX and DE and provided you've got the right alignment setup, you may not need to go beyond this unless you plan on spending lots of time at the track.
Old 02-08-2007, 05:51 PM
  #36
Jukelemon
Jukelemon's Avatar
Length i.e. ride heigth.
I cannot speak to the stiffness as that was not discussed in the article.
Old 02-08-2007, 06:02 PM
  #37
ed devinney
ed devinney's Avatar
Also, RoW M030 are progressive whereas US M030 are straight-rate. I changed from US M030 to RoW M030 on my previous 993 and got a better ride in addition to better looks.
Old 02-08-2007, 08:00 PM
  #38
InTheAir
InTheAir's Avatar
Are you sure about that? (not trying to be snide) I knew that the stock US springs were linear rate and ROW MO30 were progressive rate, but I'm surprised if US MO30 springs are linear rate.
Old 02-08-2007, 08:34 PM
  #39
95 C4 993
95 C4 993's Avatar
Any thoughts to the PSS9 Kit and that set up? Spings and all.
Old 02-08-2007, 09:08 PM
  #40
ed devinney
Ya know, it's something I read in Viken's info in the suspension FAQ and would swear that I noticed it when I changed over from US M030 to RoW M030 springs in 2000, but I'd probably swear that I saw the Kennedy assassination, too...
Still looking for data.
EDIT:
https://rennlist.com/forums/showthre...ogressive+m030
Quick Reply: Springs and shock choices
