Tunnel Cover mod re short shifter
Common wisdom is to heat & beat a pocket into this cover without shrinking the attachment bolt spacing; however, I have read of incidents where lowly suspended cars have hit this 'dimple' on the track/roadway surface ... jamming the shifter in gear. Therefore, an easily removable cover plate looked more attractive.
As I had a spare tunnel cover, there would be no loss in chopping away at it, for it was already pretty twisted up. In mapping out the shifter left to right movement, an 'oval' of 4" x 2" was cut with a hole saw and a grinder. A similar oval was traced onto a piece of wood and relieved ~1/2" with a drill bit ( Forstner type). Then, a piece of lighter gauge galvanized sheet was convinced to fit this mould with a ball pein hammer.
Basically, the new bottom cover took the shape of the desired dimple: after trimming and some more hammering, a strip of sealant was laid in and 4 sheet metal screws pulled it together over the oval hole ... to finish, some racer tape made the edges aerodynamically correct
Anyway, an alternative trick to beating the crap out of your tunnel cover and permanently deforming it - and if I smack it, 4 screws and it's off ....
By reversing the bushing in the housing, your shift tube/rod should maintain its geometry and you shouldnt have to dimple the tunnel and your shift lever inside the car should sit about 1.0" higher than stock.
