9m cam follower for high lift valve train
Hot off the machining centre, here are the shots of the new CNC machined 9m/4T 911 cam follower before we send them away to be DLC coated. This is the first finished part for the new high lift valve train design that will allow us to run 15mm of lift with road or race cams, other parts on the way soon are matching race cams, some rather special valve springs and obviously spring retainers, platforms, collets and 8mm stem valves.
The photo shows the 9m follower alongside the early 993RSR adjustable version, aspects to note are the longer pad length to cope with the increased lift, better pad support and lighter weight at 87g against the motorsport rocker at 90g. The price estimate for the production version is in the order of £200 per unit, they run with the stock 911 elephant's foot adjuster and (with the 9m cam/valve/spring package) have a safe rpm design limit of 8500rpm.
Ooooh, very nice. Is the rocker bushed or not? One of the issues I found with the 993 cam towers and the older 911 style rockers is that the variance of the width of the rocker where the shaft goes through was not consistent. I had to machine most of my rockers so they fit in the cam towner. Will these fit in the 993 cam towers without modification?
Originally Posted by Jeff96-993
Where does the weight reduction come from? At first glance it looks beefier. Also, I'm assuming it's a solid lifter design, correct?
The bore of these prototype followers is not bushed, we know about the issue of wear associated with the non-bushed 993 rockers which is one of the reasons for having the 9m followers tribo-finished and then DLC coated, the other to eliminate wear on the pad which hard-faced or chromed followers suffer from.
Originally Posted by deltawedge
Very nice. Has anyone ever made a roller rocker for the 993?
Colin,
DOHC + 4 valve as well ?? Then you could get rid of that old hemi chamber and come right up to date !
Porsche did a lot of stuff on 4 valve for the 964 but that was one feature that didnt make it into production.
Maybe a 959 replica adjusted for 3.6 ??
All the best
Geoff
All the best
Geoff
