OEM Stone Guards price ?
Hi looking into replacing my rear fender stoneguards , 95 cab. they are white in colour and i am quoted $95 US for each from Parts Heaven Ca. Is this the average going price for this ? Anyone know ?
thanks for any info.
Guy
Guy
Guy, I agree with pcar964. That price is a little steep. I've seen it at Pelican Parts for less (around 60-70 a piece). Another option is to find a local stone guard installer to do the whole install.... this is what I did, and the installer provides the material (he just cut it to make it look the same as the OEM one).
Originally Posted by InTheAir
Pelican Parts has them for $61.50 each (that's where I bought mine just recently).
If you order the clear ones, how easy of an installation DIY is it? Is there a chance that you will pull the paint off? Should you use some type of adhesive remover (3m or equivalent). I had some body work done last year and asked the body shop for a quote to replace the non-damaged rear qtr panel stone guard and they did not bid on it.... They said it was a pain in the ****... I cant believe that they would not even provide a quote for a new stone guard. Made me think that the job is too big for a DIYer.
There are a few things you can do to ~encourage~ them to come off, such as letting the car sit in the hot sun for a couple of hours, warming the engine to heat the panels, and/or using a heat gun. You might need to use some 3M adhesive remover to remove any adhesive remnants.
Originally Posted by pcar964
That's obscenely expensive. I don't know what they're going for on average, but if that's the price, I would rather use saran wrap.
Although my new ones are sitting in my garage (read: I don't yet have personal experience), as I understand it, they ~can~ be difficult to remove but some peel right off.
There are a few things you can do to ~encourage~ them to come off, such as letting the car sit in the hot sun for a couple of hours and/or using a heat gun. You might need to use some 3M adhesive remover to remove any adhesive remnants.
