993 Forum 1995-1998
Finally got it back
Old Nov 27, 2006 | 04:26 AM
atan888's Avatar
atan888
Default Finally got it back
I finally got my c4s back from the shop after a major MAJOR $$$ service clutch, brakes , fluids lots of gaskets , ac expansion valve and so on. I purchashed this car from Adam months ago. First thing done was to debadge the RUF emblem and will change it back to the porsche crest and removed some window graphics . Next step is detailing then ???
and also pianted the calipers to yellow
File Type: jpg
Old Nov 27, 2006 | 04:50 AM
FotoVeloce's Avatar
FotoVeloce
What did you use to paint the calipers? I had a pain disaster when I tried to paint the calipers on my 964 red... now I have one black and one pink caliper..
Old Nov 27, 2006 | 04:59 AM
atan888's Avatar
atan888
not so sure but let me ask the shop and ill get back with you... how did you get pink and black?
Old Nov 27, 2006 | 05:29 AM
FotoVeloce's Avatar
FotoVeloce
Black on the passenger side (I didn't attempt painting that one) and pink on the driver side after most of it bubbled but was still sticky enough to NOT be removable with even mineral spirits... i was not about to try paint stripper unless I was going to polish the calipers. Ugh. At least winter is coming soon and the daylight hours you can see the pinkish rotor (OK.. it's not like you might imagine. hot pink.. but it's fugly) are limited.
Maybe I should pull them and have a pro refinish in red or, black or.. something..
Old Nov 27, 2006 | 05:38 AM
Air Kuul TT's Avatar
Air Kuul TT
Alvin,
Post some more pics.... Did you know it needed all those items when you purchased the car? Also if I remember correctly the RUF bumpers didn't fit properly, no? But in the pics the front bumper looks pretty good. I can't wait until you put your magic touch on this car.
Nice job.
Old Nov 27, 2006 | 06:54 AM
atan888's Avatar
atan888
cleaning here cleaning there lots of cleaning to start of with. what do you need my brother? I might not need some things here. there is a lot
Old Nov 27, 2006 | 07:16 AM
Air Kuul TT
Thanks for thinking of me by big brother. Well lets see... where should I start, J/K of course. I am just excited for you... thats all.
Old Nov 27, 2006 | 08:36 AM
atan888's Avatar
atan888
no problem bro. will keep you posted....
Old Nov 27, 2006 | 09:18 AM
InTheAir's Avatar
InTheAir
Atan, thanks for bringing it back.
Old Nov 27, 2006 | 06:10 PM
atan888's Avatar
atan888
no problem jeff..
Old Nov 27, 2006 | 06:17 PM
TRINITONY's Avatar
TRINITONY
TS tail and BBS rims.
Old Nov 27, 2006 | 09:38 PM
allill's Avatar
allill
nice car alvin.
Old Nov 27, 2006 | 09:56 PM
EndlessEarth's Avatar
EndlessEarth
Mmmm, yummmy. That car speaks to me. The front bumper looks pretty good in the pic you posted. Obviously I dig the black rims. If you decide to ditch them for something else I might be interested. I know that there is a speed yellow 993TT some where in my future to keep the 993 coupe company and it will have black rims.
Old Nov 27, 2006 | 10:23 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
What paint did you use? Acetone or brake fluid will remove most. I sprayed a few coats of VHT Caliper RED and Caliper CLEAR and it turned out really well. I didn't even bother to wetsand.
You didn't wash the calipers well enough before painting so the surface was contaminated and that caused the bubbling (fisheye). After you sand the caliper wash it down completely with a 50/50 solution of water and rubbing alcohol and then dry thoroughly before painting.
Old Nov 27, 2006 | 10:40 PM
TRINITONY's Avatar
TRINITONY
This the one I used. http://www.tirerack.com/brakes/g2/caliper_paint.jsp
