C2S versus C4S
#46
Originally Posted by H20NOO
Big reds weigh quite a bit more than the standard brakes. I've had both on my 993 and for daily driving, you'll appreciate the performance advantage of the lighter brakes more than you'll ever appreciate the fade resistance of big reds.
MC
MC
Lets start w/
Porsche factory on 993RS, 993Cup, and 993tt
we will leave the middle out and end w/ me.
For every day driving, no they are not worth it, if you can feel the difference you are one ultra sensitive individual.
#47
Originally Posted by autobonrun
I can tell my C4S is quick out of the hole with the RS gear package, but I've lost my top end advantage since my 5th gear is is now 6th.
here is a simplified comparison of some of the gearing options.
#49
Originally Posted by geolab
The mechanical brake system is not the same with the turbo starting with the reservoir.
more info here
#50
Hi Bill,
I believe the gears are different on the 993 throughout the production years in order to meet some noise limits on the streets... Would you know what are these differences? I guess 97 and 98 models received longer gears than 95 or 96 cars...
#51
All US and Swiss models had the G50/20 gearbox. ROW had G50/21 initially, then towards the end, the G50/20 as well.
Gear..US/Swiss......Rest of the World ......
______(G50/20)________(G50/21)__________
1.......3.818..................3.818...................
2.......2.048..................2.150....................
3.......1.407..................1.560....................
4.......1.118..................1.242....................
5....... 0.962.................1.027....................
6........0.775.................0.820....................
Final ratio 3.44:1
Final ratio 3.44:1
#54
Originally Posted by Bill Verburg
The 993tt and 993C4S have exactly the same mechanical components, electro-hydraulicly boosted 25.4mm m/c, 322x32 and 322x28mm rotors, 36/44 Big Red front calipers, 28/28 rear calipers.
more info here
more info here
Hi Bill, just for precision on what was said,
Porsche C4S has the Turbo's brake calipers and discs because of weight and inertia in All wheels. The mechanical brake system is not the same with the turbo starting with the reservoir.
C4S Brake fluid reservoir 964 355 013 50
Turbo reservoir 964 355 013 25
C4S HYDRAULIC UNIT 993 355 955 50
Turbo Hydraulic unit 993 355 955 00
C4S brake pressure regulator 964 355 305 00
Turbo 964 355 305 10
C4S electronic Brake control UNIT 993 618 127 00
Turbo control unit 993 618 125 00
etc. etc.
#55
some facts on this.
993 355 955 00 is used on 2WD, non ABD cars
993 355 955 50 is used on M224(ABD) and M339(AWD) cars
pump
993 355 953 00 and 01 are used on narrow body AWD and RS
993 355 953 50 is used on M491(turbo look) and turbo
993 355 305 01 -1x is used on base cars
993 355 305 01 -2x are used on ABD, n/a cars
964 355 305 00 -2x are used on ABD and AWD including M491(turbo look)cars
964 355 305 10 -1x is used on turbos
993 618 126 00 n/a w/ abd control unit
993 618 127 00 M224(abd), M339(AWD), RS control unit
