Brakes - when to replace the rotors
While my pads on my 95 993 are ok, the rotors are getting to the point, I believe, where they may need replacing. Couple of questions:
- My rotors do have a slight lip at the outer rim. Someone told that that once this happens, I should be on the look out to replace. How big is this lip allowed to get before getting into trouble? Or is the thickness of the rotor the key, and how thin should it not be allowed to get?
- Is there a DIY website for rotor and pad replacement? P-car doesn't seem to have this topic, nor rennlist (although it has website link problems at the moment)
Thank you.
Thank you.
Weathergirl
Also, I noticed the inside face of my rotors wore more quickly than the outside. So they may need replacement even if there's little apparent wear on the outside.
Porsche also says to replace if the cracks reach a certain length. I think it's 7mm in front, but you should do a search to confirm, unless somebody else knows offhand.
An additional replacement criteria is if the cracks in the holes start connecting to adjacent holes. Or if the cracks start extending out to the rim of the rotor.
Had new rotors and pads at 30k and most recently 57k. Miles probably dont mean as much as actual wear. My mechanic mentioned it a few times starting at 49k to replace the fronts. I had them turned 39k. The previous set up was Zimmerman and not sure what the pads were but whatever they were, they are a little loud. Im now with OEM and Textar pads. They didnt last that long either.
As far as DIY, Im sure there are several links on this forum. Im not a DIY person.
Thank you.
Thank you.
A small lip on the outer edge of a disc brake is normal wear sign.
RallyJon gave you the limit porsche recommends not to surpass.
New disc brakes come with a 33mm thickness.
A 1.5 mm lip on each side will give you an idea that your discs are to be changed.
Be aware that if you change to new discs, you have to put new pads, and never the old ones.
As for DIY, it is exactly as changing any disc brakes on any car.
One small detail, is to sand extensively the area where your new disc brake will mount.
its the flat area on the wheel hub where the wheel threaded bolts hang out.
Usually this area is slightly rusted and should be well cleaned.
If not, you may risk wobbling while braking.
Originally Posted by geolab
...Be aware that if you change to new discs, you have to put new pads, and never the old ones...
According to the Porsche Service Manual, the disks are 32mm new, and the minimum acceptable thickness is 30mm. They can be machined as long as both sides are machined symmetrically. (I've never heard of anyone wanting to do this). If the lip is more than 1mm on either side, you should replace. Agree that old pads will fit new rotors quickly, (after a few hot stops), but "as long as you're in there...."
Originally Posted by TheOtherEric
I disagree. Using old pads with new rotors is perfectly fine.
From what I've seen, I think the problem is that grooving in both rotor and pad can occur that can be exacerbated by a grooved pad that alters a new rotor. I wonder how deep the grooves would get if you kept on putting on grooved pads with new rotors over the course of ten swaps?
If you say so
Originally Posted by Mark in Baltimore
...From what I've seen, I think the problem is that grooving in both rotor and pad can occur that can be exacerbated by a grooved pad that alters a new rotor. I wonder how deep the grooves would get if you kept on putting on grooved pads with new rotors over the course of ten swaps?
