Denso Iridium?
I've already ordered a set of Iridium plugs based upon prior favorable experiences with them. In fact, my other 2 cars have been running these for some time now. Both cars have direct ignition, however, unlike the 993's cap/rotor setup.
I was very impressed with the performance of the Iridium plugs the first time I tried them. I hadn't really expected much, other than a longer useable life. After all, I change plugs often enough that I usually feel guilty about throwing away what appear to be perfectly good plugs (so now I have a fairly large collection of very good used plugs), but these seemed to make an immediate improvement in smoothness and throttle response. I've used Denso Iridiums ever since.
So if I'm so convinced, why am I asking for input on this issue? It's all TheOtherEric's fault, really. I ran a search and came across just a few posts on this topic and one of his really got me worried. Apparently his GF's car had one self destruct in the combustion chamber, which is something I would like to try and avoid.
So. Any other horror stories out there, or was this an isolated incident?
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Rennlist Small
Business Sponsor
BTW, whatever happened to the rather strong Splitfire marketing campaign??
The NGK site shows a three electrode ( carbon steel?) BCPR7ET for the NA cars, and a two electrode '6' heat range plug for the turbo; however, no link to their Iridium iX series.
Like I said, I had already ordered the denso Iridiums based on previous favorable experience with them, after which I just decided to run a search here to see what others thought.
I don't think these things are based upon the same sort of marketing gimmickery that brought us the infamous Splitfires. The reasoning behind the use of platinum or iridium in this sort of application is sound. If it allows a slightly larger gap and/or provides a longer usable life, all the better, since plug changes are no joke on these cars.
As far as the argument that the manufacturer, Porsche or otherwise, specifies a particular fluid, tire, brake pad or plug - I think cost plays a very large part in this equation. If everything were perfect from the OEM, we wouldn't spend so much time and money swapping out so many different OEM parts for more expensive, durable or better performing pieces. The "G50/G64 Transmission Clutch Shaft Fix-It Kit" comes to mind.
I agree with Geoffrey:
Thanks again.
