No spiders with OE pads?
Weathergirl
Doing front brakes this weekend and I ordered the OE Textars from Stoddard after reading many threads here. I was surprised to see they came without spiders. They do have a full size anti-squeal plate on the back of each pad, though.
Do the spiders have a separate part number? Have they been phased out entirely?
Spiders (Anti-Squeal pads) are ordered separately. Some guys don't bother with them. I suppose you could add them at a later date if you do have a squealing issue.
The part numbers go something like this:
965 351 096 00
964 351 096 01
965 352 096 01
964 352 096 00
I would check PET to be sure.
965 351 096 00
964 351 096 01
965 352 096 01
964 352 096 00
Weathergirl
Meh. I guess I'll try without. Stoddard got back to me and the spiders are $4.27 each. But I'm doing the rotors/pads this weekend and I'm not paying for FedEx. I assume if they are squeaky I can pull them apart and add them later.
They squeak right now with stock pads, but that might have something to do with 29.5mm thick rotors and almost worn out pads.
I changed my front rotors/brakes this weekend. Its very easy to remove the spiders from the old pads and transfer them over.
Squeeling brakes is a personal pet peeve, and I figure since I'm there now and don't want to have to open it all back up again, I'll just re-use them.
1 Post
Originally Posted by C4S_fan
... Its very easy to remove the spiders from the old pads and transfer them over.
Weathergirl
Originally Posted by Marv
I noted that the back of my OEM pads I just got have a shiny metal backing. Is that new?
Technical Guru
