DIY screw up ....
Those details that when forgotten can cause you problems during days or month, details that can cost you money or stress before you finally find the cause and cure it.
I will start with mine:
When I performed my first engine drop, everything ran well... But at every bump ma car was feeling on the road, a weird "clonk" sounded somewhere in the back. I checked all the engine mounts, bolts etc... Nothing wrong until after a few weeks I finally found that I forgot to lock a bolt which holds the gearbox support to the body!
one of the six yellow arrows!
Go ahead MikeJ, yours is even nicer!
During my suspension install that resulted in the DIY instructions in my signature, I was reinstalling my upper spring perch on the front right corner of the car. I'm not sure if it was my screw up or metal fatigue, but when I was tighting one of the 13mm nuts (even before torqueing), I sheared one of the threaded studs right off. Unfortunately, those threaded studs are integrally formed with the upper spring perch, thus requiring a brand new perch....... $135'ish. Ouch.
Thus leading to the following warning in the DIY instructions:
TIP: The proper Porsche spec for the torque of these four (4) 13mm nuts is 24 ft/lbs. However, there have been cases of the stud shearing off under 24 ft/lbs, possibly due to metal fatigue. If this happens, you will need to replace the entire spring perch. (Ask me how I know.)
I knew the price seemed cheap! But it looks like a Turbo......guess thats what I get for buying a 4S
I was installing an Optima battery in the car before the Portland Parade a few weeks ago since the lead acid one was toast. You have to bend the positive terminal because the posts are farther in on the Optima. I had the battery in, positive just about right and negative not connected. I was bending the positive just a little bit more with a set of vice grips and my hand slipped......
and my Engineer's ring on my pinky touched the negative WHILE I was holding the wrench. 600 Amps discharged through the ring and it turned red hot. Holy Crap!! I ran out of the shop up the stairs to the house and the door was locked!! I fumbled fo the keys as the ring continued to burn into my finger...I then got in and put the finger/ring under cold water. Now what? Loks bad!! So I did a DIY ring removal...I first checked that the finger was still strong enough for the twisting and then started to reef on the ring (which had not been off for more than 20 years). I managed to get it off by rotating the ring on the burn and then twisting it off with soap....
The doctor told me that it was a smart move which likely saved my pinkey. Its pretty bad burn right though the skin into the meat all away around the finger. I have been changing dressings for the last three weeks, no swimming this summer, and taking showers with your hand in the air is a pain in the a**.
So what did I learn from this "DIY"?
1 - Wear mechanics gloves when installing batteries.
2 - No rings (even though I have done 20+ years of fooling with cars with my engineer's ring)
3 - Flamizine ointment is your friend.
3 - Damn batteries can sure kick!
Cheers,
Mike
When you are waxing/polishing your car:
-- take off your wristwatch and, yes, if you have a humungo ring -- that too!
-- do not wear pants that require a belt or sport any form of 'big' belt buckle
-- do not wear jeans/dungarees that use 'copper studs'
-- have a 'clean' t-shirt and 'clean' pair of shorts and a 'clean' pair of sneakers on 'standby'. Why? Because after you have completely skanked up the set of clothes that you have been wearing all day (cleaning the car) -- if, at the end of the day, you 'forget' and then get in the car to put it back in the garage -- you have just 'ruined' your seats/vinyl and, yes, steering wheel too.
G.
https://rennlist.com/forums/993-forum/276761-don-t-do-a-bonehead-maneuver-like-i-did.html
RIP Ray.....
A coupe of years ago there was a GB on RS motor mounts. The DIY looked simple compared to other work I've done in the past (suspension, brakes, etc.) Anyway, I get the first mount replaced with no problem and then proceed to replace the second.
I get both of them in and get out my torque wrench to tighten them down to spec. I adjust the wrench properly and begin to go at it. The wrench keeps turning and turning and it never clicks. Needless to say, I snapped the bolt in the body of the car (there was something wrong with the wrench).
However, I then decided to try and drill out the broken bolt from the body and ended up breaking/jamming a diamond blade bit in the hole with the broken bolt. I tried for hours to get it out but didn't have any luck.
So I call up my Porsche independent shop and make an appointment to drive it there for them to fix it.
According to my mechanic, it took them almost 14 hours to get it out because the diamond blade bit would not budge. They tried a number of times to weld a nut to the exposed bolt and that snapped off without the bolt budging. They eventual had to make a "jig" and slowly drill out (from small bit to large bit) the entire mess without damaging the original threads on the part that's welded to the car.
That cost me $1200 and is probably the most expensive motor mount install ever on a 993!
On the other hand, I have had a shop scew up a few things after doing work on my car-like forgetting to screw back down my CD changer in the hood and oil run off from an oil change. Nothing like having your oil changed, come home, load the car up and getting ready to head to Tellurdide and you notice a big oil spot in the driveway. I dont know how many people let oil drain on the engine tray but that was first for me. I no longer use that shop and they did thousands of $$$ in work but the got sloppy on the little things. Nothing better than paying a bill for $5k in upgrades, then your stereo starts acting up and look in the trunk to find the CD changer is no longer screwed back on and bouncing all the place.
Marc
