~Pictures~ The Horror of Wheel Wells
Well, I've wanted to do this for about the last year and especially this summer--clean the wheel wells to remove the 10 years of nastiness that is grime, grit, grease, oil, cosmoline, and a bit of tar. The previous owners never got under the car, but instead just brought it to the dealer for service. Obviously, dealers don't clean.
In March, when I got under the car to replace the suspension, I was confronted with the horror that is my wheel wells. Since March is not the time for outdoor washing sessions here in Michigan, I ended up replacing the suspension and putting off the undercarriage cleaning.
Well, today was the day to pay the piper. With g_murray's recent post, it was enough to push me over the edge. I went out and bought 6 cans of Gunk Citrus Degreaser, some brass brushes, some nylon brushes, and some brake cleaner.
After removing the wheels and soaking the wells with degreaser (about 20 minutes), I pulled out the power washer (2300PSI) and started at it. You would not believe the amount of crud that came out of those wells! I repeated the process 3 times per well, including scrubing the problem areas with the brushes. After I was done, I dressed the wells with Aerospace 303 Protectant and moved to the wheels themselves. Although they had some attentions a few months ago, it was time to scrub again.
You can see from the pictures below, it has been quite a transformation. It certainly isn't full concours level, but it is a HUGE improvement!! (MORE PICTURES HERE: http://www.pbase.com/jlsphoto/porsche_wheel_wells )
Here is the RR before the suspension install
Here is the RR after the suspension install with one crude cleaning at the local carwash, but before the detailed cleaning today
AND NOW AFTER!!!
Here is the right front before the suspension install
Here is the right front before cleaning today
AND NOW AFTER!!!
OVERALL, IT IS A HUGE IMPROVEMENT!
AND NOW AFTER!!!
AND NOW AFTER!!!
Jeff,
That is a HUGE difference!! Looks great! Not sure if I would ever go quite that far, but fully appreciate the effort and results.
Couple of quick questions. First, do you think the degreaser and/or power washer forced water has any negative consequences when/if it gets into the suspension joints? Do you get everything relubed afterward? Second, you mention that you're onto the wheels next. I'd be interested in how bad your starting point is, what you're using for the work, and the results. I've got a couple of sets of Kinesis wheels that have some really nasty baked on brake dust and other crude on the inside of the wheel and I'd like to do something to bring them back to reasonable shape.
Kind regards,
Kind regards,
Very nice Jeff! I've been thinking along the same lines after g_murrays detailed concours prep .... but more of a 'show & shine' level job with a jug of Simple Green, Citrus spray bombs and a pressure washer. You've convinced me ....
Poseur
A very nice job! That's a nasty area! (One little photography tip,--run on the new rotors a few miles BEFORE you shoot the after shots,--then they will be rust free!)
Many times I have considered that, but instead of ~mounting 4 wheels, lowering car, torquing all lug nuts, driving, rejacking the car, removing the wheels, photographing, remounting the 4 wheels, lowering the car, torquing all lug nuts~....... I think you guys can use your imagination on what shiny rotors would look like.
Originally Posted by Cy
Jeff,
Kind regards,
Kind regards,
With regard to the wheels, I already did them. A couple of them were VERY bad to begin with. While I was waiting for the degreaser to dwell on the wells, I sprayed the citrus degreaser on the inside of my wheels and then let them dwell for 10-15minutes. After which, I used a sponge with a mild scrubby on the back to gently scrub the wheels. I didn't push very hard but instead just let the degreaser do the work. After being sprayed off, there is a little bit of cosmoline on the interior surfaces here and there and I did not scrub the grooves along the BACKSIDE of the spokes, but overall they are 90-98% clean.
Where did this event take place? Your garage floor is spotless. Did you manage to do this in a coin operated car wash? ( I don't think so) What became of all this crap you washed off?..
What was it.................Wheel Well Day?
I worked mine over and after a long DIRTY day my results are good but not as good as yours. There were a few places where stuff just would not come loose.
Yours looks new. Great Job
