Just did my belts...
Tech article rates this as a 6 out of 10. I'd say it was a 2-3, but getting my a/c compressor back in place was an 11. That bolt closest to the rear of the car and the fan housing was HELL!!!! All my strength and a pry bar weren't enough. I got lucky and was able to thread it after an hour of rage. Otherwise it was a cinch. Although I ordered the correct 12 pt. M10 tool on eBay, it didn't arrive today and my new belts did. So I used the old Lisle star bit I had and just Dremeled it down. It fit perfectly into a 1/2" SAE box wrench. Socket and ratchet on it were still too thick for the space.
I recommend using zip ties to keep the washers and shims together and tighten them down so you keep them from flipping out of the order in which you removed them. I had no problem with the three allen bolts. But I will be ordering new ones for the next time I do this. In my previous comments on a belt thread, I was wrong about being able to hold the fan down with your hands instead of using the 12 pt. tool to hold the shaft still. I didn't realize that shaft spun independently of the fan, as it does not in older 911's. Photos to follow.
Here's the 12 pt. Lisle bit in a 1/2" SAE box wrench. Don't skimp on the tape. And don't do this without a glass of Gentleman Jack, seen on the upper right side. Maker's Mark or **** Creek will do too. But nothing else!
Here's how to do it. I rested the top side of the box wrench against the underside of the rear crossmember, so my hands were free to turn the 24mm wrench. Key here is to make sure the 12 pt. tool is seated totally FLUSH. Don't skimp on this. 2 min. of double checking can save hours and $100's when you strip it.
Note that bolt sticking out on the left side of the compressor. Easily, one of the top three most frustrating things I've ever done on a 911 and that's saying something. BTW, I turned the engine over a few times with the key to get the belts to seat and set tension by feel.
I second John D's recommendation about putting a rag over the crank pulleys to catch stuff you drop. I was careful and didn't drop anything down there this time. But I have done it plenty of times before and it's always good to have a telescoping magnet and claw grabber tool handy for this. I should have been done in one hour. But it took me two Rush CD's (Hold Your Fire and Fly By Night) and three glasses of Gentleman's Jack to do it. I've just passed my one month mark with no cigarettes and that damn compressor almost broke my will to stop smoking. Gawd, it sucked! As the tech article says, with the three allen bolts, be sure to get the socket bit totally flush. Mine weren't very tight, but it looks like they had been wrenched on in the past and I will get new ones next time. I bought two of each belt so I could change them and have spares for next time or an emergency. In a roadside emergency, I'd just cut the a/c belt and deal with it later.
Great write-up, Rick. I had to do replace the alt and fan belt last weekend at the Glen. I also just ordered the 12 point tool from ebay as per your recommendation.
Why are you selling your SC???
Rick,
Good job. I should have taken pictures as well. I actually had more trouble with the bolt behind the a/c compressor (I got my hand stuck, holding the lower nut )
Technical Guru
I know, I know. But I've thumb tensioned v-belts in my other Porsches and never had a problem. I just drove her a good 40 miles and when she cools off a bit, I'll recheck the tension. If I find someone with the right tool, I'll use it.
Thanks for the writeup Rick. I went out to do this today, as my A-Belt has a couple of small cracks in it...but I found that the tool kit didnt have the 12 point tool...
Is the tool that you used available from any hard ware store? Id like to do this tomorrow AM and wont have the official tool.
