Initial ride height settings for h&r springs & hd's
Does anybody have some initial ride height settings they used for a H&R sport springs and VB's HD Bilstein setup? ROW Sport and Standard. Pics of either one would be appreciated too.
Thanks...
Thanks...
Here's what I did:
On the fronts - Lower spring perch 30mm up from the bottom of the threads.
On the rears - Lower spring perch 204mm up from center of bolt hole.
This is how it turned out:
Yep, if you want the proper 1% downslope at the front, the front ride height will be at least 1/4 inch higher. With the H&R springs and Bilstein HDs, I always used 25 front and 24 3/4 rear.
Originally Posted by rooster20
Can a widebody wear 295/30/18's?
Thanks Bull. I spent the second half of the day @ the local Porsche dealer fitting and testing 295/30/18 on 996 Hollow spokes on my C4S. Even with my H&R/Bilstein setup (verrry low) they work well... no contact to the body. Finally getting everything sorted. Pictures to follow.
Originally Posted by faster
Gordo993, what size tires are you running? the rear looks great, do you have any rubbing in the front? thanks
Rears:265/35/18
On 18" hollow spoke technology wheels - no rubbing!
Originally Posted by gordo993
Here's what I did:
