993 Forum 1995-1998
Creaking normal when to body flexes/torques over driveways??
Old 06-17-2006, 11:29 AM
wannaB_turbo
wannaB_turbo's Avatar
This is great! I mean, all along it was making me nervous, but I am SOOOO glad to know that the creaks are normal.
BTW, I have the PSS9 suspension and a strut bar as well.
Thanks guys!
--Andy
Old 06-17-2006, 11:39 AM
geolab
geolab's Avatar
I just posted a new thread with a solution I found that applies to me, I hope it works for you guys
_______________________________
'97 Carrera S 100% original
Old 06-17-2006, 12:07 PM
mborkow
mborkow's Avatar
at least the windshield does not creak like the 993
i keep reading about this, but i have no windshield creak at all *knock on wood* --and i am on windshield #2 now.
Old 06-17-2006, 12:18 PM
texas911
texas911's Avatar
My 993 creaks, windshield is what I think it is. My 997 does not creak at all although I hit the black plastic air dam all the damn time.
Old 06-17-2006, 12:57 PM
TomF
TomF's Avatar
As many of us know, a properly installed windshield can make all the difference. With my last windshield, there were no creaks until it got mildly "shattered" by a golfball-sized piece of concrete. Then it really creaked. With the new one, which was properly installed, it is totally quiet again.
Doug, if you dash is creaking, try removing the ashtray and loosening and then re-tighening the bolt behind it while slightly holding up on the dash. It really worked for me. The dash slowly wiggles loose at this point over a period of time.
Old 06-17-2006, 05:25 PM
pchak
pchak's Avatar
Mine creaks a little, so I'm glad it's normal. I notice it most when I'm making a turn on an uphill off camber. How about door rattle on the cabs? I've replaced the latch grabs, and the doors aren't sagging, but I still get a little rattle if I hit the right (wrong?) bumps.
Old 06-17-2006, 05:29 PM
Anir
Anir's Avatar
The strut tower brace didn't seem to help my creaking that much, and I agree that it's worse since installing the PSS9's.
The Porsche manual recommends using Vaseline to lubricate the front sway bar bushings, and this, along with periodically tightening the sway bar brackets, has helped quite a bit. I think some of the PSS9 creaking might be coming from the springs moving slightly, but I'm not sure.
I wish I "enjoyed" the creaking as much as some of you.
Old 06-17-2006, 05:51 PM
geolab
geolab's Avatar
I was faxed this from porsche stuttgart two minutes ago, Anir you are totally right, the USA manual is different.
Old 10-17-2007, 10:27 AM
unclespeed
unclespeed's Avatar
I have good and bad creaks - my windshield doesn't much creak at all to bother (luky me -for now- perhaps). I only get some little noises that sound like a very muted hail storm (sounds pretty sweet)...
...but yesterday the rear started rattling (my rear window, I think). Is it due to the RSRs?? This is very annoying, as it keeps me from hearing the lovely sounds of that exhaust. I first thought it was being caused by my son's booster seat in the back - and when he was riding with me the sound was gone. But now it is back and I am able to reproduce by lightly hitting the rear panel under the window...
Any thoughts / suggestions on how to remedy this?
Old 10-17-2007, 11:08 AM
AShearer
AShearer's Avatar
+1 Exactly my experience.
Old 10-17-2007, 12:54 PM
Don Magee
Don Magee's Avatar
Geolab, I looked and did not find your recent thread. Would you mind giving me a clue? Merci.
Old 10-17-2007, 01:10 PM
g_murray
g_murray's Avatar
Am on my third windscreen. All three squeaked.
I've heard (but have not 'done') the 'Pedro's wax' fandango - which 'quietens' the rubber-creaks -- mainly because I've heard that when your windscreen needs to be replaced AGAIN - that's the installers will curse you to high heaven because everything has to be chemically-cleaned so as to make sure that the glue 'takes'.
Gerry
Old 10-17-2007, 01:49 PM
geolab
geolab's Avatar
Hello Don, Here is the link I was talking about. I think remedy is any greasy substance
but make sure it contains zero H2O inside, regards
https://rennlist.com/forums/993-forum/280564-how-to-remove-squeaking-creaking-noises-and-torsion-sounds-solution.html
Old 10-17-2007, 03:31 PM
dcdude
dcdude's Avatar
I have new front and rear glass. The front creaks. Looks like it wasn't properly installed. It does sound like an excuse for a KLA strut brace.
"Hello, slope? Meet slippery. Slippery, meet slope."
Old 10-17-2007, 03:44 PM
NP993
NP993's Avatar
I have no creaks of any kind (88K on the odo). I guess I'm lucky.
Quick Reply: Creaking normal when to body flexes/torques over driveways??
