Axle replacement
Axle replacement
Has anyone replaced a complete rear axle and wheel bearing? What tools are required? Also, what's the opinion of aftermarket axle assemblies? MUCH cheaper but any good?
Thanks, Tom '91 C-2
Thanks, Tom '91 C-2
I did wheel bearings on a 96 c2. This involved removing the outer half of the axle. With the bearing puller tool from EBS and the pcar diy site, it was uneventful. I don't believe the inner half of the axle involves anything more than unbolting it from the flanges.
Pete
Pete
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The only part of this work that limits people is getting the proper torque on the driveflange nut (335ft.lbs). The wheel bearing requires this clamp loading. Other than that, its not hard at all..
You can always rent a torque wrench that size...I assume the brakes can hold the hub still enough to put this much torque out?
Cheers,
Mike
Cheers,
Mike
Yes, the brakes do fine in holding. P-car.com has a writeup on the bearing R&R, which requires an axle R&R too. Check there.
I believe the same writeup is on the DIY section of Rennlist too...
Have fun, I'm doing the same thing right now...
Technical Guru
Originally Posted by Tom Andrejack
Has anyone replaced a complete rear axle and wheel bearing? ...
Thanks, Tom '91 C-2
Thanks, Tom '91 C-2
For any Carrera 2 produced before November 28, 1991 the nuts are torqued to 460Nm (339 ft-lbs). For a Carrera 2 with VIN greater than:
960 NS 420564 Coupe
966 NS 440189 Targa
968 NS 460593 Cabriolet
the nuts are torqued to 420 Nm (310ft-lbs). Unless your Carrera 2's was produced after April 1, 1992 with a VIN greater than:
966 NS 420701 Coupe
966 NS 440208 Targa
966 NS 460916 Cabriolet
in which case the torque spec is 460Nm (339 ft-lbs). The spec is also different for roadster, turbo, etc.
