993 Forum 1995-1998
Disabling spoiler
Old Jan 25, 2006 | 10:07 AM
Arena993's Avatar
Arena993
Default Disabling spoiler
I have searched past threads and found 2 options for disabling the rear spoiler so the light on the dash does not come on. one method I found was to unplug the unit in the passenger side footwell and the other method was to jump the wires. I have attached a picture of the module under the passenger side dash. will unplugging this do what I want (disable the rear spoiler and light). I am replacing the decklid with a TT tail. Thanks for the clarification.
Mike
Old Jan 25, 2006 | 10:23 AM
InTheAir's Avatar
InTheAir
Mike, yes that is the one according to this DIY:
http://p-car.com/diy/tail/tailwarninglights.htm
Old Jan 25, 2006 | 10:43 AM
Arena993's Avatar
Arena993
Jeff;
I'll give it a shot. Thanks for the help. this DIY also has the jumper method. I'd rather unplug it's easier
Mike
Old Jan 25, 2006 | 01:23 PM
Jeff96-993's Avatar
Jeff96-993
I did the jumper method in the rear compartment... no problems.
Old Jan 25, 2006 | 01:51 PM
pcar964's Avatar
pcar964
Sorry to hijack the thread here, but is there a way to RETAIN use of the manual spoiler switch to move it up and down, but DISABLE the automatic deployment of the tail? Right now I've been pressing the manual button down for a second and up for a second in order to get around this, but I'd like a more permanent solution - I like keeping the tail up most of the time, even at low speeds.
Thanks!
Old Jan 25, 2006 | 01:58 PM
mborkow's Avatar
mborkow
once the spoiler deploys it remains so until you drop beneath 5 mph, right?
Old Jan 25, 2006 | 02:07 PM
pcar964's Avatar
pcar964
I believe it's 8mph -- the probem is stop and go traffic, where it might go up and down 20 times in one trip. I hate that, and it will obviously wear the motor out much faster than just keeping it up most of the time. I don't do a lot of stop and go driving (I avoid it like the plague in my 993), but sometimes you can't avoid it.
Old Jan 25, 2006 | 02:20 PM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
But I thought if you raised the spoiler manually before reaching 50 mph it will remain up even after you have stopped the engine? But will reset the next time you start the car again until you go through that 50 mph - 0 cycle.
Old Jan 25, 2006 | 02:33 PM
epj993's Avatar
epj993
I think this is correct - per the owner's manual.
Old Jan 25, 2006 | 02:38 PM
havoc's Avatar
havoc
On my 95 I found that pulling the plug on the footwell unit disabled the cruise control. I have never seen this mentioned on any of the threads, so it might be unique to this car. Last weekend I built and installed the jumper option and reconnected the footwell speed unit. Now I have the cruise control operational and no spoiler light.
Jim S.
Old Jan 25, 2006 | 02:43 PM
Robin 993DX
Lifetime Member
Don't have that problem on my 96 after pulling the plug. Would be interesting to see the schematics on the 95 and 96 to see where the difference are.
Old Jan 25, 2006 | 03:37 PM
pcar964's Avatar
pcar964
Yes that's true - but I'm trying to find a way for it to NOT reset every time I start the car... maybe I'm getting greedy? haha
Old Jan 25, 2006 | 03:51 PM
dhicks's Avatar
dhicks
I would like to hijack for one question....when I start my car the red spoiler warning light comes on and stays on until I start moving, when it goes out and never reappears again until my next engine start....is the same for everybody.....
Old Jan 25, 2006 | 04:16 PM
Jastx's Avatar
Jastx
That's why I got the RUF spoiler control module for my C4S. It eliminated the rediculous up and down around town but did raise it at around 75mph. A great mod, I thought. They don't offer them new anymore from what I understand, so if you come across one, snap it up.
Old Jan 25, 2006 | 05:59 PM
Evan's Avatar
Evan
David,
Yes, they should all do that. I think the light kicks off at 2-3mph IIRC. It's in the manual.
I have a '95 and the cassette under the dash is for the spolier and had zilch to do with my cruise control. When I purchased the car I had a fixed wing and the PO had unlugged the module and the switch and light never came on. I also think when the PO re wired the 3rd BL, there were only the red & Black wires for power and ground hooked up. He had pulled them out of the clip in the engine bay. I have since put it all back together, wired it back and plugged the module in and - Voila all works fine again.
