rust bubble on panel
under the rear window on a 96 993. It was repaired by Porsche under warranty. I have not seen it yet, it's been done to a car I am considering buying. My question is, is this a common problem area? are there any other things to look for pertaining to this? I spoke with the service writer who remembered the car and he stated it was a small area where water accumulates,and there were no other issues. I want to ask you guy's, the experts, for your opinions. Thanks.
Quite a few 993s have had a bit of rust on the side of the rear windows (mine included). It apparently often comes from the low quality seal that Porsche introduced for the 993 and/or poor rear window replacements. I've not heard of it being at the base of the rear window or of a water trap. Where would this water come from?. Either way the glass has to come out, the whole surround is blasted, cleaned up, treated, etc and typically a high end shop would pretty much spray the roof so it's not a $50 touch up!
If it's the only negative then I wouldn't let it put you off as long as the repair is to a satisfactory standard. Ask them to check very carefully round the windscreen frame as you may find rust there; again it's an increasingly common problem in the UK; primarily due to poor windscreeen fitting.
Good luck!
Regards,
David
Good luck!
Regards,
David
I have a copy of the repair invoice, it has 3 part #'s listed. one is for a window seal, another for a rubber seal and another p/n 993-545-107-12 Rear Window. Was the rear window replaced? Can anyone tell by the p/n I listed?
Seared
I've read about cases of rear windows shattering because of a defect with the third brake light wiring. The car you are looking at may have had this issue in the past.
Or maybe an asteroid crashed through the window
Andreas
Andreas
I too would appreciate any other feedback from other 993 owners that have had this problem?
I too have 3 small bubbles I can see/feel under the rubber around the window...size of a pea. I think I've got this year to bring it to Porsche before warranty is up. Opinions on whether its worth it?
The bubbles have not changed in the couple years I've owned the car. It probably sees wet weather 2-3 times a year max and its garaged.
I had mine done last year and had to push for it - not too much but they wouldn't pay without a fight!
If it's starting to rust, it ain't gonna get better by itself. Use the warranty while it's there!
There is a tape that should be applied, if removed from, under the seal around the screen, this stops the seal and any accumulated grit rubbing againt the bodywork as the seal moves at speed. it is more important for the front screen as I have found out, the paint has completely worn through in one or two spots exposing the metal and making it vunerable to rust.
thanks Sidned, I hadn't thought of that. I tend not to think in terms of selling her but some day it will happen.
FYI I just moved from Surrey UK last year....had the pleasure of driving a LHD 964 with no heat, oil leak, and windscreen squeak but I still miss those B roads......I got up the M1 to Northhampton quite a bit.
