Jack plate for 993
Hi Everybody,
Does anyone know where I can buy a jack plate tool to use with a two tonne scissor jack in the UK? What do you use to avoid damaging your bodywork?
Thanks and regards,
David
Thanks and regards,
David
I use a hockey puck with a 1/2" cap screw. A plain hockey puck works well too. Not an original idea, heard about it here first. I'm running out the door, will snap a pic later today...
Sorry to be a bit thick but how does a hockey puck sized pad help as from memory this would be too big to sit into the jacking point? Am I missing something?
Cheers,
David
Cheers,
David
Hi Kelly,
I'm mainly interested in just lifting the back up a bit if I need to change my mufflers so I assume I can jack up the car using the normal jacking points but obviously one of those look to be quite small compared to the "plate" on a hydraulic car jack. I seem to remember when I had my old 911 that you could buy plates that fit into the jacking point and onto the car jack so that you didn't damage the bodywork when you were using it. What do you guys do?
Cheers,
David
Cheers,
David
Have you seen this on Pcar? http://p-car.com/diy/jack/
When I work on the back of the car, I lift from the engine as shown in the DIY. I always put the car back on jack stands under the rear side jacking points. You will have to remove your engine cover, though, to be able to lift from the engine. If you feel nervous about lifting from the engine, autometrics makes an engine jacking pad that you bolt to the engine so you have a nice solid area to lift from...
http://p-car.com/diy/jacktowpoint/
If I lift from the side, I use one of these at the rear side jacking point then put a jack stand under the front lifting point. Others have used a hockey puck between the jack lift surface and the lift points to prevent metal to metal contact.
HTH...
Here is what I use...of course home made...
A closer picture...
These hold the jack stands locked to the car and work great.
I also did a variation for the jack itself....got a little more fancy..
![](http://forums.rennlist.com/upload/zulo_jack_stand_1.jpg)
A closer picture...
![](http://forums.rennlist.com/upload/blue_dark.jpg)
![](http://forums.rennlist.com/upload/mvc0005_copy1.jpg)
The 993 column in the Porsche Club of Great Britain, Porsche Post (Jan 06) describes something that seems to match what you are looking for. Column was written by Ken Coad. You might want to email him 993@porscheclubgb.com.
Originally Posted by John95cab
Those are fancy. I just use a piece of plywood
Cheers,
Mike
