Engine Rebuilt Part III - Heads and SAI passages
#31
CEL=Check Engine Light. I was paranoid about this until I read the manual 'cause mine didn't come on. Now I've been on the forums a while I'm glad we don't have it!
If you look in the UK manual the turbo's have it but not NA (normally aspirated) cars.
#33
Originally Posted by Caveman
Sorry to be a bit think here but what are these keyways used for? Is this to do with the better 964 cam location/fixing?
Cheers,
David
Cheers,
David
Cheers,
Mike
#35
Thanks Mike,
I now understand. So how does this link with these comments about using old 964 gear wheels?
Cheers,
David
Cheers,
David
#37
Mike,
could you tell me if it's possible to see, without dismounting the cams, if they have the key way?
David if you're interested, here's a post from 993RS about valve timing
