993 Forum 1995-1998
Engine Rebuilt Part III - Heads and SAI passages
Old 01-09-2006 | 01:18 PM
Mike J's Avatar
Mike J
Originally Posted by tam993
So wait a minute, I'm confused here.
Does the air from the SAI pump come throught the cam carriers or what ever they are?
it appears to be so... or am I wrong.
I'd like to know the routing of those passages. I'm doing a flush on my car. PITA. First they are flowing
well, the next day they're clogged. Must be that carbon carp up in there.
Ok, the flow of the air is roughly...
The air pump sucks the air through a rubber hose from the air cleaner. It passed through the pump, a controled valve and into the famous one way valve on the top of a air distribution manifold. This manifold splits the air into two metal lines, each going to the back of each cam tower. At the cam tower the air is received and routed through a passage in the cam tower to each head. The air passes through the interface between the cam tower (carrier) and the head into the passage down through the head into the exhaust chamber...**whew***
There is not trace of carbon at the entrance to the cam towers so its all down below there. You can see the significant crap buildup in the cam towers where they meet the heads above.
Maybe you are getting some of the carbon loosened and its plugging the hole...notice how small these holes are...
BTW mine all flowed fine...its was worn valve guides that triggered the rebuild.
Cheers,
Mike
Old 01-09-2006 | 01:29 PM
Mike J's Avatar
Mike J
Originally Posted by Toga
But to my opinion, with about 75k mi, my engine doesn't need it yet.
Cheers
My idea was just to to the top end as well here are some reasons to go all the way:
- With 75,000 miles all the wear surfaces (rings, bearings, etc) will have wear, not significant but still there
- I do not know what the PO did to the car so I feel much better taking it down to the bare bones and then I know what I have
- Its not that much extra work and cost once you are down to the head.
- Its best to catch any problems before anything wears out. I have finished the dissassembly (I need to get to posting) and there was a bit of wear on some of the bearings...nothing to worry about but it had started to wear at the bearing shells
- It good to replace the Rod bolts since they have a history of stretching if an overrev happens (like on the track with a missed shift). Replacing them with ARP or Raceware is a very good idea (I am using ARP on mine).
So that was the idea behind it...peace of mind and a fresh engine from top to bottom. While you can argue that the bottom ends can last 200.000miles + since I did not control the first 80% of the car's life I can't say what the internal condition was. Most people argue the average bottom ends seem to go 120,000 miles. If I do the whole thing I should have another 100,000+ miles from the engine without having to rip into it again...
Turns out i my case that it was marginal to do this but I have seen some wear and now I will feel much better about the engine overall.
Cheers,
Mike
Old 01-09-2006 | 04:02 PM
Jastx's Avatar
Jastx
Mike,
A tech at my Porsche dealer (Boardwalk in Plano, TX) mentioned when they do an SAI job they bore out certain passages to eliminate the problem or make it less likely in the future. I don't know the details but have you heard about that?
Old 01-09-2006 | 04:11 PM
NoSubEDU's Avatar
NoSubEDU
Originally Posted by Dr. P
Hello there. I've been lurking here for about 2 months now. I don't even have one of these cars but I do plan on getting one in next year or so....anyways, to get to the point....excellent work you are doing here Mike, but I decided to chime in with a chance to give you a piece of advice.
I know I'm a total stranger here but for some legibility, I'm a quattro guy and have had Audis and worked on them myself for 6-8yrs now, but its totally up to you to accept this or not. perhaps cosult others. So, by looking at that SAI port, I would suggest, once you clean it real well, you take the grinder in your hands and polish that port to a mirror-like finnish. Even better yet, if you could have it lined with Teflon coating it would be the best. The reason I suggest this, unless there is already a better method for preventing this clogging, is that I and many other have had had a bad experience on Audis V6 12V engines. The EGR(exhaust gas recirculation) port that goes from EGR valve through intake manifold and exits just after the throttle body was so small that often got clogged with carbon buildup, which would throw a CEL(check engine light) and help you fail emissions. The best solution was to take IM off and polish that port to a mirror finish. When I did so, it was good for next 3 years, after which i sold the car but even the guy that bought it never had problems to date. Mind you, it used to clogg every year or so if cleaned and left as is(abrasive alluminum).
Hope this helps and good luck with the rebuild, its quite an experience and you'll find so much more joy in driving the car afterwards!
Would this be Dr. Phil? If so, welcome to the board! Great first post...
Old 01-09-2006 | 04:29 PM
Dr. P's Avatar
Dr. P
Thanks for the welcome, but I'm not by any means a doctor, let alone Dr. Phill. My first name is Peter, but Dr. P was a quick handle pick and references to Dr. Ferdinand Porsche I'm sure I'll change it to something more apropriate in the future, I'm still in the process of learning about these cars and doing something more than a basic research before I'm ready to buy the most beautiful 911, that is 993, ever made. And being the last air-cooled I believe it will keep its values high.
Old 01-09-2006 | 05:51 PM
tam993's Avatar
tam993
Thanks for the explaination of the air passages,for the SAI crap, makes sense now.
I had 5 of the 6 flowing like they were wide open and the next day nothing.
I have another question, evidently there is one gallery for the air the "T"s off for each exhaust port right?
Old 01-09-2006 | 06:09 PM
Adrienne's Avatar
Adrienne
Great pics again, Mike. I'm thoroughly enjoying keeping up with your saga. Just FYI...your SAI ports look only slightly cleaner than mine were at 110k miles. I'll not bother posting the pics here, but mine were almost completely clogged. It took many expensive hours for the shop to clean them. Not a fun task.
Old 01-09-2006 | 09:36 PM
Mike J's Avatar
Mike J
Originally Posted by Jastx
Mike,
I have not heard of this but it sounds like a good idea. I am not sure if the passage is a straight line in the heads...it looks like it but there is so much gunk in there its hard to tell.
Can you find out more (like do they bore the heads and to what extent? I am hoping that with the new guides etc. I will not have any problems with SAI...yeah right....
Cheers,
Mike
Old 01-09-2006 | 09:38 PM
Mike J's Avatar
Mike J
I will take some pictures when the cam carriers get back from the machine shop...I sent them in to have them cleaned. There is one gallery for each side, i.e. pistons 1,2,3 and then 4,5,6. That gallery feed each of the heads. I hope I answered your question?
Cheers,
Mike
Old 01-09-2006 | 09:39 PM
Mike J's Avatar
Mike J
: I hope my 96 4s have them too, because I'd really like to make that valve timing adujstment mods
Cheers
Hi JP,
What was the build date on your car? Mine was Jan/96. If its before that that its very likely you have the keyways. How much longer after that date I do not know.
Cheers,
Mike
Old 01-10-2006 | 06:45 AM
Caveman's Avatar
Caveman
Sorry to be a bit think here but what are these keyways used for? Is this to do with the better 964 cam location/fixing?
Cheers,
David
Old 01-10-2006 | 09:43 AM
Toga's Avatar
Toga
Originally Posted by Mike J
Hi JP,
Cheers,
Mike
It's a May 96 car. But an X51. I don't know if they are using the same cams as the 3.6... Going back in my doc, I think I should find something about it.
Old 01-10-2006 | 11:01 AM
tam993's Avatar
tam993
yes, that answers my question, I suspected that. I suspect the port to the exhaust is a straight drill too. (from the top of the head to the exhaust port).
what happened on my car was the check valve failed and allowed the exhaust to blow back up in the ports... I guess.
Regardless, I was cleaning them via the flush method and basically made things worst. I would have been ahead of the game if I just dropped the engine and pulled the cam carrier off and cleaned them that way.
I don't think my SAI ports were clogged from bad valve guides, there was little to no build up on the exhaust valves or exhaust ports.
Lame design.... Are only US versions of this engine doing this sort of thing. Like to people in Eroupe have these issues?
thanks
Old 01-10-2006 | 12:52 PM
sidned's Avatar
sidned
I think it's onl you guys in the US that have this feature. Our CEL lights don't work on NA cars. I think it's an emmissions requirement for certain US states (someone correct me if I'm wrong!).
Old 01-10-2006 | 12:54 PM
Caveman's Avatar
Caveman
What is a CEL anyway? We don't have this stuff over here and have a lot less engine plumbing because of it. ;-)
Quick Reply: Engine Rebuilt Part III - Heads and SAI passages
