SAI Flush Complete...
First, before I even get into the write-up, I have to thank ViperBob.
There are no words to express my gratitude to someone who's answered every one of my calls and every single question over the last 2 months. He personifies the rennlist spirit, helping me throughout this process with both technical advice and moral support. Truly amazing.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
About 2 months ago, I started off doing the SAI with Scott (a fellow rennlister who spend many hours on his weekends helping out.. yet another Rennlister who was willing to sacrifice his time to help someone out!)... getting the old check valve resulted in breaking the air distributor housing it sits in. You can see the thread with some pictures below..
https://rennlist.com/forums/showthre...ight=SAI+broke
Long story short, I had to exchange the first distributor as it had a burr in it. While I waited another week for air distributor to come in, I bought a 16mm @ 1.5 die to clean up the airhose flare nut (just in case).. and then I waited for the distributor.
Once the distributor came, I did the flush and none of the ports were blocked.. they all whistled clean! Scott & I spent 8 hours bolting the distributor down and I began the process of putting everything back together.
After I buttoned everything up top, Viperbob recommended that I drop the bottom 6 spark plugs, pull the fuel pump fuse and crank over for 10-15 seconds to make sure the cylinders were clear.. they were.
I re-attached the heat exchangers using new gaskets. The stealership wanted $35 per piece... and you need 6 of them. My local gave them to me for $5 and gave me 12 new locking nuts to attached the exchangers to the studs (instead of charging me $5.50 per unit like the dealership wanted to...)
With the heat exchangers in place, I started the car up for the first time in 2 months (yes, I had to buy a charger)... it started right away with 3-5 seconds of blue smoke and then ran clean!!
I'm so excited that everything is now back "in its place".. I went for a spin... wow, did I miss driving this car! Which is what I plan to do for the next 30 years![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Here is the new air distributor in place..
Here is the sprinkler pipe and brass tee I used (thank you Scott C. aka campbesl.. ) to put the solvent into the air distributor.
Here's another with the air-compressor end visible..
I've take some better pictures of the new and old check valves..
![](http://www.dennispi.com/gallery/albums/CarbonFlush/IMG_4470.sized.jpg)
![](http://www.dennispi.com/gallery/albums/CarbonFlush/IMG_4454.sized.jpg)
![](http://www.dennispi.com/gallery/albums/CarbonFlush/IMG_4451.jpg)
![](http://www.dennispi.com/gallery/albums/CarbonFlush/IMG_4449.jpg)
![](http://www.dennispi.com/gallery/albums/CarbonFlush/IMG_4471.sized.jpg)
Dennis......GOOD JOB!!!!...finally. I'm glad everything went smoothly on the startup. We can now get back to that long awaited cup of Starbucks. I am anxious to see your car on the ground with the new suspension. Glad you are up and running!
It was my pleasure Dennis. My contribution however was very small. You were the one turning the wrench (and with the battle scars to prove it) and now have the satisfaction of a successful DIY... Congrats!!!!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I would venture to say every 30K miles, including flushing. If one drives his or her 993 short(er) distances (not allowing for full warm-up), maybe every 15K miles?
Good job and a very good show of patience....I guess you now understand how important it is to get a second elbow installed in each of your arms so you can work on these cars? ;-)
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
VERY true... an extra elbow would have made this job much easier. I stopped by a local shop and told them I was replacing the air distributor.. he told me that I was nuts to do it without dropping the engine.
Originally Posted by dgetz993
Awesome! Great PICS and great job... How many miles were on your car?
