Autozone pads ok?
Ok, the pagid oranges on the street were ok for a while, now am ready to go back to stock till spring.
Have the OEM ones ready for the back, none for the front. Any prob using the types of pads Autozone sells? Even better they come w/ a lifetime warranty!
Looking at
DURALAST Semi metallic BRAKE PADS - FRONT for a 1997 PORSCHE 911 AWD TURBO
Unit Price: $56.99
Core Value*: $0.00
Part No.: MKD594
Weight: 4.0 lbs.
Warranty: LLT
Looking at
Unit Price: $56.99
Core Value*: $0.00
Part No.: MKD594
Weight: 4.0 lbs.
Warranty: LLT
I am only half kidding when I say "Autozone" and "Porsche 993 Twin Turbo" should never be used together in the same sentence.
Try looking on TireRack.com They have some Mintex brake pad sets on the cheaper side and at least you are getting somewhat of a brand name.
Also, you should consider the fact that many "Lifetime" warranty pads "are" Lifetime warrantied because they are hard as diamonds and wear out the rotors instead of the pads. And rotors on a TT are not cheap. Just something else to consider.
Is my memory failing or did Glen say that he ran Autozone pads on the track...and would exchange them under the lifetime warranty?
Can't find his post and too busy to spend much time looking but I'm pretty sure it's out there.
https://rennlist.com/forums/showthre...light=autozone
George,
I'm still in D, but the "wing" does not have a leading edge as per the CR requirement. I've, um, modified it so that it passes muster, but I have another idea in the works.
The winglets are from a really cool guy in Pennsylvania named Hugh Dehoff. He was kind enough to make a set of them to fit onto the curves of a stock 993 bumper. They're actually too wide, IMO, but I think Hugh would be willing to produce them in a more narrow configuration. Let me know if you want more info on them.
King of Cool
...The winglets are from a really cool guy in Pennsylvania named Hugh Dehoff. He was kind enough to make a set of them to fit onto the curves of a stock 993 bumper. They're actually too wide, IMO, but I think Hugh would be willing to produce them in a more narrow configuration. Let me know if you want more info on them.
Thanks!
