Antisieze paste on spark plugs
Has anyone ever used Champion ANTI-SIEZE 4OZ 2612 S on their spark plugs? I know the workshop manual says to put plugs in dry, ie without any lube or antiseize?
This stuff is used on spark plugs in air cooled Lycoming and Continental aircraft engines.
Passed On
![Thumbs down](https://rennlist.com/forums/images/icons/icon13.gif)
I haven't used this, but used the stuff that came in a tube on my old '84 Carrera. Got a jammed spark plug which resulted in requiring an engine removal, head removal, and drilling out the jammed plug. Never used anti-seize stuff again.
Shop manual sez install them dry; I'm a believer.
I also thought one of the reasons Porsche wants them installed dry was to get good grounding for the sparkplugs? I guess its possible with an even caot of antiseize to have the plug insulated and the sparks will not be as strong....not sure but I put them in dry as well.
Cheers,
Mike
Cheers,
Mike
if the product is for high temp i will use it.
i use loctite equivalent, only a very small amount, just to cover the threads.
i have destroyed many expensive aluminum parts in my striker aluminum sportfisherman as iron-stainless get frozen inside the aluminum, specially if external humidity is around. (As in Florida or southamerica)
if the product is for high temp ratings, i will use a small amount of it , as a way to prevent frozen parts later on. is my humble opinon as engineer.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I have 2 other antiseize products one is copper based and has a temp rating of 2000 degrees F. and the other is kinda of silvery in color and is rated to 1600 degrees F.
Edited
Am I correct in think that the temperature of a spark plug would not exceed 1000 degrees C. which is about 1832 degrees F?
One reason Porsche says no anti-seize on spark plugs is so optimum heat transfer from the plug to the head is maintained, thus ensuring proper functioning of the plug. To reduce the possibility of a plug seizing, be careful not to overtorque them.
Yeah, and be careful not to undertorque them. I did this on a plug in my 87 cab years ago, and it worked it's way loose. It sounded like I was running straight exhaust! Of course this happened late at night in a very quiet, exclusive and expensive neighborhood... also known as Medina. The gendarmes were not happy!
