Rim offset 1994-993
Rim offset 1994-993
Hi,
Will someone please clarify my rim offset my handbook says 55mm front & 70mm rear but people keep telling that this is incorrect regarding the rears and it should be 50mm for the rears.Im very confused
Pete
993 C2 1994 Man
Pete
993 C2 1994 Man
That depends on what size the rim width is that people are refering to. For example, an 18 x 10 for the 993 (narrow body) rear should be 65mm and for the wide body rear, should be 40mm.
Tell us the wheel type and sizes front and back and we'll be able to figure it out.
OEM 17" wheels have a 55mm offset on both 7" front and 9" rear wheels.
If you have stock wheels, the width and offset should be cast into the wheel on either side of the valve stem.
offset
Hi,
I have targa wheels on my car which are split rims no markings either side of vavle stem anywhere else? my handbook states 55mm front & 70mm rear so which is correct?
cheers
Pete
cheers
Pete
Pete,
Are they OEM wheels? 70mm on the rear of a C2 w/ 17" wheels does sound off... but then, I could be wrong... wouldn't be the first time.
Perhaps someone with a targa will chime in to give you info from their car.
Originally Posted by 964driver
...Will someone please clarify my rim offset my handbook says 55mm front & 70mm rear but people keep telling that this is incorrect regarding the rears and it should be 50mm for the rears.Im very confused ...
In researching wheels and tires over the last few months, I've come across quite a bit of info, hopefully this little bit will help you out:
http://www.pca.org/tech/tech_qa_question.asp?id={389561CF-0369-40BE-B293-559BB9305DAC}
I don't know how to do the cool 'link hidden behind a word' trick.
Hope this helps.
Hope this helps.
Earliest 993´s (at least some ´94 euro models as mine) with 17" Cups had 9 x 17 rears with ET 70.
At some point (´95?) the rear offset was changed to 55, which certainly looks nicer as it fills the rear arches better than ET 70.
Mika
Mika
