Who has coolest wheels on their 993?
#1786
http://tires.about.com/od/understand...-Structure.htm
http://tires.about.com/od/understand...nd-Flanges.htm
#1797
Originally Posted by HiWind
very nice shine and elegant package .. what's reverse mounted mean?
Originally Posted by kkswow12
So when reverse mounting the wheel gets a deep look....? Does the ET change.?
For example, here are my wheels with the face mounted on the lip.
#1798
With 2 or 3 piece wheels you can either front, sandwich, or reverse mount the wheel "face". Since Knight's bbs lm's are a 2 piece style setup, he has mounted the rim face behind the barrel which effectively lowers the offset and pushes the wheel outwards. Looks perfect imo.
Yes and yes.
Yes and yes.
As a comparison, you can see the face of the rim is behind the barrel here.
#1799
See the two following links... and the diagram below. I think the reverse mounting he's referring to is explained in the Wheels Anatomy 201 section.
