What lube to use on mainshaft/flywheel pilot bearing
I'm in the final stages of getting everything rounded up before doing the engine drop.
New Mobil 1 engine oil, 14 Ea.: Check
Mobil 1 gearbox fluid, 3 Ea.: Check
Turkey baster: Check
12 pt. tool for flywheel bolts: Check
Clutch alignment tool, 1 Ea.: Check
Power Steering fluid: Negative... need to figure out if mine uses Pentosin or whatever, first)
Torque wrenches, 2 Ea.: Check
2 six packs, Shiner Bock: Check
Red loctite for flywheel bolts: Check
Olista Longtime 3 EP, Mainshaft/pilot bearing lube: NEGATIVE -And I don't know where to find an equivalent. Is there anything I can easily buy over-the -counter for this or am I going to have to call a dealership?
Yeah, I bet that would go over like a turd in a punchbowl... "Yes, is this the service department? Could you squirt some of this Olista Longtime 3 EP into an envelope and send it to me?"
Ahem... please see my location below my avatar... ...closest dealer is either Calgary, Canada (6 hrs), Denver, CO (13 hrs), or Bend, OR (~15 hrs) I have no idea where the closest independent shop would be? Boise, I think.
Living in the middle of no-where sucks. Damn Air Force.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Leland Pate
um... see my second post.
Seriously, there may be a BMW dealer in Missoula or something. I'll have to call around.
What a pain in the ****.
RL Technical Advisor
You'll have a container of that stuff delivered to you tomorrow (Saturday) by your friendly UPS man,...
Yup, all by my lonesome.
I'll have a few friends standing around, watching. I don't expect them to do much because most are "mechanically inept."
I'm just waiting on the new transmission (should have it in a few weeks) and then it's "go time."
