993 Forum 1995-1998
CDR 210 Question
Old Dec 14, 2015 | 07:10 AM
GT917's Avatar
GT917
Originally Posted by jansan946
The illumination lead goes to pin A6 and if you want the radio to light up when the lights are switched on and adjust for brightness, you need to tap power from the gray/blue ashtray light wire. This was the way Porsche did it at the factory when they ran short of the CR/CDR 210 radios during the 993 run and had to substitute the CR/CDR 220. There is a Porsche TSB on that here: http://www.pcarworkshop.com/index.ph...C_Parts_Guides See #5 in Body and Interior TSB's.
Thank you for this update, very usefull !
Do you have any clue on where I could connect the A6 pin to 12V powered when contact is On (even if Lights are Off) ?
Old Dec 14, 2015 | 11:39 AM
jansan946's Avatar
jansan946
What radio are you asking about, please?
Old Dec 14, 2015 | 12:10 PM
GT917's Avatar
GT917
CDR 210.
Old Dec 14, 2015 | 12:19 PM
jansan946's Avatar
jansan946
Illumination for the CDR 210 is controlled by the radio's off/on switch. If you want to always have it illuminated, the radio's wiring would have to be modified and I have no solution for you.
Old Dec 14, 2015 | 12:41 PM
GT917's Avatar
GT917
My question was unclear, sorry :
I would like the radio to light up when the lights are switched Off or On, so I need to tap power from any place powered as soon as the car is on.
Hope I'm clear. Cheers.
Old Dec 14, 2015 | 05:13 PM
jansan946's Avatar
jansan946
OK, here is a diagram of the back of the radio:
Referring to Socket A, my CR 210 radio has connections to pins 4 (Permanent positive), 5 (Control output for automatic aerial/amplifier), 7 (Switched positive) and 8 (Earth).
You can tap +12 V from the leads to pins 4 or 7. But my radio illumination is controlled by its Off/On switch.
Old Dec 15, 2015 | 05:13 AM
GT917's Avatar
GT917
Once again, many thanks to take care of me
So, it means that I can tap +12 V from the leads to pin 7 : it will not be a pb to power both the radio AND the screen with the same only one switched 12V ?
Another question please, what do you mean when stating '... my radio illumination is controlled by its Off/On switch' ? which switch do you refer to ?
Sorry for being such a dummy !
Old Dec 23, 2015 | 12:49 AM
pp000830's Avatar
pp000830
Originally Posted by FisterD
I have the same issue, and was also told pin 6 is the one. I was going to tap into the cig. lighter for the illumination, but haven't done it yet.
Not a good idea as the lighter is always powered even when you are out of the car. Run a wire to the ignition switch or even beter, if there I a power amp control pin on the radio use it.
