LWF Help!!!
LWF Help!!!
Just had a LWF installed, now the car stalls. It is a 96 c4, the ISV was cleaned. Also the battery was disconnected, will it just need some time to reset itself, or do it need to do the reset prcedure. the Idle is low about 500 rpm should i adjust the isv or not?
I was informed when I did my LFW that anything after 95 was good. Your idle is way low though, mine is about 800....you will find however that you need slightly more revs to get the LFW cars to take off, if you try taking off with too few revs it WILL stall...its something you get used to very quickly and by more revs I do not mean many but you do have to be aware of it.
Good luck, once you get your stalling issue sorted you will LOVE IT TO DEATH
From: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
How many mines did you go after disconnecting the battery? It takes about 30 minutes of driving to get the computer to work right. I hope that is the issue!!
On my previous 95, with the LWF, JohnD fussed with the ISV a couple of times and got the idle up to 900 or so, and the car very rarely stalled after that. That's the way to go, I think.
Vic
95 C4
Vic
95 C4
Vic
95 C4
Vic
95 C4
How is this adjusting of the ISV performed?
Originally Posted by Alon
My idle is usually around 550-600 and I fel that it is a bit low even though it has never stalled
