Performance makeover time for a 993
1. PSS9 suspension with TRG adjustable sway bars - what diameters? I'd stay away from the TRG bars...they are cheap but they lack welded on collars...they have collars that are bolt ons. If they get loose, the bars will slide from side to side under load. If I had to do it over, I'd stick with the Porsche RS 23mm front 20mm rear.
PSS9...I have them...they seem OK. Wdhen I went from M030 RoW suspension to PSS9s...I didn't see a world of difference. Maybe I would now that I have more track seat time. I have had trouble with the front adjustment screw binding up on the PSS9s.
2. Carbon strut tower brace up front. Why carbon fiber? Just install a factory bar...not that expensive.
3. Carrera RS shift kit - where do I get one of these? Haven't found a web source. As mentioned above, Gert Carnewal sells them, Steve Weiner sells them. Steve is in Portland, OR, Gert is in Belgium. Note, they lack some of the rubber isolation of the factory shifter...there may be more cabin noise or some harmonic vibration, maybe not. I extracted mine and sold it off for this reason...but that was just me and my car,
4. And now the big question. I need some advice on 18" wheels and tires. These will be used mainly for autocross/DE/Time trials. I realize that there is a tradeoff for compounds for autocross vs. high speed events. For the wheels, light weight is most important. Aesthetically, I prefer a 5-spoke design, but a BBS-type web is also acceptable.
Wheels: Look to Kinesis and Fikse. On Fikse, the retaining bolts are on the inside, easier maintenance. The BBS wheels are beautiful too. They are a little spendy and may not me the best wheels for the streegt. But for the track, incredible.
Tires: Will you be driving to the track or being towed? If you are driving the best overall combo tires for me are the Toyo RA-1 and the Yokohama A 032R. These tires get real noisy when they have a little wear.
Hi Craig,
Gosh, oversteer is such a subjective thing and, honestly, I would be loathe to make a sweeping generalization and say that the TRG bars are the sole or primary cause of the looseness, which rears its head on high speed, Type 1 turns that lead onto straights.
Handling set up and how a car feels is very much dependent on driver preference, shocks, spring rates, tire compound, sway bar settings, toe in/out, camber, alignment, etc. that it can be a real Rubik's cube to figure out. With my set up, I also have the added bonus of being able to change the pressure in the shocks, as well as the compression and rebound. You might drive my car and say it handles perfectly. I like for the car to have some understeer because it gives me more confidence to push it. If the car is overly loose, it's great fun, but I also think it's kind of slow to be countersteering so much.
One might think it best to stick with a completely non-adjustable suspension and be done with it, but I really like coming into the paddock, taking tire temps/pressures, tweaking rebound, etc. and writing down my feedback and lap times. It's all about learning for me and, if I didn't have any adjustability, it wouldn't be as much fun. For others, this may be a track nightmare.
FWIW, my TRG bars have been faultless. Contrary to many early posts that discussed squeaking or loosening collars, I have had zero problems with them.
DJ 996,
They are street legal wheels, and I got them from a German company called Inden Design. Here's the link:
http://www.indendesign.de/html/bildergalerie_pic_anzeigen.php?jumpback=html/kfz_galerie&bild_id=282&start=24
I originally wanted to get them from BBS, and phoned BBS Germany, but they told me that they give this particular version exclusively to Inden.
Originally Posted by GratefulJED
"I love the colour of your car Phil"
You should have seen his last 2, um, 1!!
Eeeer.... I still get uneasy whenever I see speed yellow, but once in a lifetime is enough...
I also have the TRGs and am happy with them. The noise issue was cured with some good lubricant and the updated collars. As far as the understeer - I have none. I run a 245 tire up front with the front sway on full soft and the rear sway on the middle setting. I had longer drop links, I would try the rear on full stiff and the front on mid stiff.
The Fiske Profil 5....is a really nice 5-spoke.
http://www.wheelenhancement.com/index.php?t=WheelDetail&id=121
