993 Forum 1995-1998
Targa wheels instead of Turbo twists
Old 08-10-2005, 02:50 AM
kkim
kkim's Avatar
Originally Posted by TargaTango
Could someone please teach me how to quote properly from a message in a thread?
Hit the "" in the bottom right corner of the post you are trying to quote.
Old 08-10-2005, 03:08 AM
infinii
infinii's Avatar
All the best,
Look at the bottom right corner of each quote and you see some graphic quotation marks. If you put your mouse over it, it should say "quote...". Click on it and it will quote the entire post. then simply delete the parts that aren't important.
Old 08-10-2005, 10:52 AM
97Targa
97Targa's Avatar
Originally Posted by jkuniverse
Craig, I love your Targa! and yes, that will be my next mod.
I've changed the wheels and I like them very much. The car feels more compliant over the bumps probably due to the 17" wheels.
Thanks Jason, yours looks sharp too. Not very many around either. I can't remember the last time I saw another one at a local event.
Old 08-10-2005, 02:41 PM
Texas993
Texas993's Avatar
Hey Chris.
I didn't say the are light, just lighter than my 18s! I have heard that the Speedline Targa wheels are quite heavy.
I will weigh them next time I swap.
"pjconner
Honestly, the car drives better with the 17" Targa wheels. They are lighter than the 18's."
Patrick, Are you sure that they are lighter? I had my Targa 17's weighed and they were anything but light at Fronts 24.2lbs each and Rears 27.5lbs each giving a hefty total of 103.4lbs. This does not compare favourably with the now discontinued 18" Veloce GT1's which totalled 67.5lbs. I am guessing that the 18" twists would total something in the 80's.
Jason, I like the look of the Targa wheels, have no problems with them filling the arches with my RoW M030 suspension settings, and from what I understand they provide a performance and comfort advantage over 18" wheels and tires assuming that the tread contact width is the same.
All the best,
Old 08-10-2005, 09:07 PM
jkuniverse
jkuniverse's Avatar
...Patrick, Are you sure that they are lighter? I had my Targa 17's weighed and they were anything but light at Fronts 24.2lbs each and Rears 27.5lbs each giving a hefty total of 103.4lbs. This does not compare favourably with the now discontinued 18" Veloce GT1's which totalled 67.5lbs. I am guessing that the 18" twists would total something in the 80's....
Hey Chris,
I had this information in the archives... The Targa wheels are lighter than the 18" solid twists but heavier than hollow ones.
...................................Technology (hollow)...............Turbo Look (solid spoke)
7.5x18 ET50 (Front)...............................................993.362.134.06 --24.91 lb
8x18 ET52 (Front).......993.362.136.00--19.95 lb.......993.362.136.01--25.57 lb
10x18 ET65 (R-NB)......993.362.140.01--23.36 lb.......993.362.140.04--29.32 lb
10x18 ET40 (R-WB).....993.362.140.00--25.13 lb........993.362.140.03--31.08 lb
Old 08-10-2005, 09:13 PM
fbfisher
fbfisher's Avatar
As the cars age there will be a greater appreciation for the orginal stock form. Think of your 993 as a 356 30 years from now. I went back to 17" cups and I like the "classic" look, even though its only 8ish years old. It does ride and handle better too.
Old 08-10-2005, 10:03 PM
TargaTango
TargaTango's Avatar
Hey Chris,
Jason, Thanks for this info and Patrick I now understand your point. I wrongly thought your 18's would be much lighter. I now feel a lot better about my Targa wheels! I have not been able to find anything really light (in the 60-70lb range for a set) in 17", or even in 18" to which I would only reluctantly go to. So I had them repainted and they look great to my eyes.
fbsisher makes a good point about the "classic" look. I often hanker for something new as I hope it will give some performance advantage, and then I catch myself. I really enjoy reading about some of the older P's. Great thing about the 993 is that it allows you to enjoy the old and the new at the same time.
Thanks to Kelly and infinii on the posting tip.
All the best,
Old 08-11-2005, 12:16 AM
renn911
renn911's Avatar
Personal if I had to keep one set I’d go with the Targa wheels. I agree with you the Targa wheels give the car a unique look. Beautiful car with either wheel!
Old 08-11-2005, 01:13 AM
jkuniverse
jkuniverse's Avatar
Thanks renn911. I agree...definitely a keeper.
Old 08-11-2005, 01:17 AM
Texas993
Texas993's Avatar
Hey Chris. Was having the wheels refinished a big deal? Wheel Enhancement here says they cannot refinish these wheels because they cannot source the wheel bolts. (2 piece wheel).
My Targa wheels are a 7 out of 10 which is fine for the track, but not if I want to keep them on the car.
Let me know how the refinish went. I know you are in HK. Thanks.
Old 08-12-2005, 02:10 AM
Mike J
Mike J's Avatar
Hi Patrick,
I went to our local wheel refinisher here in Vancouver and they said not problem to refinish the wheel. They made up a special tool to get the bolts off and they strip, turn and repaint the wheels. They don't think matching the color is a big deal. They charge about $150CDN/wheel.
Cheers,
Mike
Old 08-12-2005, 02:25 AM
TargaTango
TargaTango's Avatar
Patrick, I had the refinishing done a few months ago at the eqivalent of USD64.10 per wheel. My shop simply took the wheel bolts off. They did not replace them. They kept the car a few days and the whole operation was very straight forward. I would recommend it if you can get a good shop.
All the best,
Old 08-12-2005, 12:09 PM
skegler
skegler's Avatar
I vote for the Targa wheels, too...I love the way they look. Glad to hear they drive well, too.
Old 08-12-2005, 12:12 PM
Texas993
Texas993's Avatar
Thanks Mike and Chris. Sounds like a future project. Good to know I can have them fixed. Sounds like Wheel Enhancement just didn't want to fool around with them.
Old 08-12-2005, 12:15 PM
Mike J
Mike J's Avatar
The two things I don't like about my Targa wheels is they are a real bear to clean (the little bolts are countersunk and you need a toothbrush to get in there) and they look a little small on the car. I do like the 5 spoke pattern though...
But a nice set of RUF wheels would look better on the car.... ;-)
Cheers,
Mike
Quick Reply: Targa wheels instead of Turbo twists
