993 Forum 1995-1998
Brake Rotor replacement choices?
Old Jul 30, 2005 | 05:07 AM
MrRoboto's Avatar
MrRoboto
Default Brake Rotor replacement choices?
It seems like the only choice for a 1996 C2 is OEM? Aren't there any two piece design replacements for the front rotors? Brembo has a new Turismo Brake Kit that utilizes a larger-than-stock two piece rotor with an adapter kit to make it work with the stock caliper, but i don't see a fitment for a 993. Any ideas?
Old Jul 30, 2005 | 08:09 AM
solsrch's Avatar
solsrch
My idea would be to go with stock rotors (cap painted) or get the brembos from Brumos while they're on sale. I don't do high speed racing stuff, only autox, so I went with stock rotors while thinking this through a few months back. I don't have fade issues and didn't increase the unsprung weight.
Old Jul 30, 2005 | 09:04 PM
MrRoboto's Avatar
MrRoboto
Brembos from Brumos? Do you have a link? Thanks!
Old Jul 30, 2005 | 10:32 PM
solsrch's Avatar
solsrch
Pretty sure they were still running the special in this month's Excellence. If you can't find them let me know, but a yahoo/google search should take you there.
Old Jul 30, 2005 | 11:18 PM
KOAN's Avatar
KOAN
Are you having any problems with OEM? I mostly track my car, and find they work well and are relatively inexpensive. What are you trying to improve?
Old Jul 30, 2005 | 11:21 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
As Chuck mentioned, the factory rotors do a good job when one compares price vs. durability.
Old Jul 31, 2005 | 04:53 PM
Martin S.'s Avatar
Martin S.
Talking Brake article worth reading...
The last two (2) Panoramas have had a brake article, parts 1 and 2 by Alan Caldwell and Bob Gagnon. It is extremely well done as you would expect from these two guys.
The Big Reds, or possibly better yet, the Big Red fronts and the 993RS Red rears, do provide a few advantages...the biggest being that they will stay cooler longer under had useage. They probably won't stop you any faster.
The downside, rotors are about $150 a pop and brake pads (Pagid Orange) are over $400 for front and rear pads.
I have Big Reds on the care because they came with the car (Thanks previous owner!). Would I spend the money and do this upgrade if I didn't have them? Probably not...I'd put the money into a Guard or Porsche Motorsports LSD. Now this mod will make you go faster (around corners!). And isn't that what its all about? Well it is for me anyway. That's my $0.02.
Old Aug 1, 2005 | 09:21 AM
dhicks's Avatar
dhicks
Where is the best place to get stock rotors?
Old Aug 1, 2005 | 10:49 AM
vuugti's Avatar
vuugti
Why a Rennlist sponsor off course!
During a conversation with VB last week, parts are pretty hard to come by anywhere now, so I'd get them where you can.
I do have a set of slightly used front and rears, stock ones I removed when I went with TT fronts and RS rears. Virtually no wear on the fronts.
Andy
Old Aug 1, 2005 | 10:59 AM
tlark's Avatar
tlark
http://cgi.ebay.com/ebaymotors/Porsc...temZ7968531541
No afiliation, just bumped into them and they appeared to have reasonable pricing.
Old Aug 1, 2005 | 12:09 PM
sccasey's Avatar
sccasey
Default 993 rotor source
I just got a set from Vertex -- $109 fronts, $99 rears
Old Aug 1, 2005 | 12:43 PM
Rezal's Avatar
Rezal
I think the two-piece rotors are Big Red only (and only the fronts). Unfortunately, they are not a true floating rotor design.
Be vary of rotors advertised as OEM Zimmerman as Zimmerman makes them both for Porsche and for aftermarket. OEM's supposedly are more durable:
https://rennlist.com/forums/showthre...=zimmerman+OEM
Old Aug 1, 2005 | 02:15 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Be vary of rotors advertised as OEM Zimmerman as Zimmerman makes them both for Porsche and for aftermarket. OEM's supposedly are more durable.
True on both counts,.......
The majority of people really don't want full-floating rotors for street use due to noise and maintenance issues.
OEM 993 rotors are NOT made by Zimmerman although they are an OEM supplier to Porsche. There is a big difference in quality (longevity) between the aftermarket, cheaper Zimmerman's and the Porsche factory rotors so Caveat Emptor on that.
FWIW, We only use the factory rotors on these cars. (in stock all the time)
Old Aug 1, 2005 | 11:43 PM
MrRoboto's Avatar
MrRoboto
Steve, how much will all four OEM rotors cost me?
Old Aug 2, 2005 | 04:02 AM
Hi Jimmy:
I sent you an e-mail,.....
