993 Forum 1995-1998
Engine Carrier
Old 06-24-2005, 01:13 PM
Hoosier_Daddy
Hoosier_Daddy's Avatar
Default Engine Carrier
Part # 993 115 021 90 (Engine Carrier / Rear Engine Support)
Has anyone out there had theirs break? I almost had my motor scraping the ground last week while at Watkins Glen .... The Technician (30 year guy) has never seen one of these carriers break.
Keith S.
Old 02-12-2008, 08:08 AM
993Porsche
993Porsche's Avatar
Default Engine Carrier Break
Keith S.
Good possibility that mine is bent. Could you give us details on how you repair it? Pics would be good too if you have them.
Ken
Old 02-12-2008, 09:20 AM
cabrio993
cabrio993's Avatar
Never heard of one breaking. Did it break at the solder joint?
Old 02-12-2008, 09:45 AM
guards red
guards red's Avatar
Quite a common problem if none standard engine mounts are used. You can get stiffer than RS ones but should only install them with a strengthened engine mounting bracket. It usually fails where the tube (that the engine mounting bolts go through) is welded to the main metal plate of the bracket. Strengthening usually envolves welding a gusset plate there. Have you none standard mounts?
Old 02-12-2008, 09:51 AM
Mark in Baltimore
Mark in Baltimore's Avatar
I've also been told that the issue is exacerbated by having the standard tranny mount up front and solid/RS mounts in the rear.
Old 02-12-2008, 12:40 PM
Tom W
Tom W's Avatar
I heard of them breaking (a friend while at the track) and mine was bent and looking bad until it was reenforced. They break or bend right at the mount (the area just interior to where the number 1 points to).
Old 02-12-2008, 12:46 PM
Mark in Baltimore
Does anyone have any suggestions on how to reinforce it, other than to perhaps weld on some six inch or so tabs to better distribute the load?
Old 02-12-2008, 12:48 PM
Hoosier_Daddy
Originally Posted by 993Porsche
Good possibility that mine is bent. Could you give us details on how you repair it. Pics would be good too if you have them.
Ken
Ken,
Mine was the carrier and there is no repair. Replace and make certain the new one is reinforced as suggested above. This issue has been increasing as these cars (964/993) get older.
h_d
Old 02-12-2008, 03:30 PM
race911
race911's Avatar
They'd break from time to time on the pre 3.6 cars. Noticed mine one time at the track, too as I walked up to it from behind in the hot pits where I'd parked and wondered why the muffler tip is almost on the ground!
First 3.6 one I saw break was an RSA that had been made into a race car from basically new. So maybe in '95?
Old 02-12-2008, 03:44 PM
Hoosier_Daddy
Exactly what happened to me! That and during the run right before noticing, I was saying to myself, "man, this thing is shifting a little odd" (HA! HA!)
h_d
Old 02-12-2008, 06:06 PM
viperbob
Former Vendor
viperbob's Avatar
Hey Tom W., do you still have the pic of the reinforcement I did to your engine carrier? I posted it one time on Rennlist, but can't find it at the moment.
Mark - To reinforce you want to box-in the existing carrier where it meets the tubular end. You then curve this reinforcement piece around the tubular end. OK, I don't even understand what I wrote. Let me look for the pic...
Wow, I found the pic... This may help explain
Old 02-12-2008, 06:14 PM
Mark in Baltimore
Sweet! Thanks, Bob.
Old 02-12-2008, 07:43 PM
Tom W
Tom W's Avatar
I'm glad you found it Bob. I've posted it a couple times but don't have it on this computer.
That job was done about 4 years ago. The engine has been out 3 times since then (it's out again now) and it's holding up just fine. The damage occured with stock engine mounts (not RS or anything else). I've used RS mounts for the last 4 years and will be going solid this year (along with solid transmission mounts). My car is track only and sees about 30 hours of track time per year.
Old 02-12-2008, 09:03 PM
forklift
forklift's Avatar
Really dumb question, but can this reinforcement be done w/ the engine carrier in the car?
Old 02-12-2008, 09:10 PM
Mark in Baltimore
Man, I 'm hoping so.
Quick Reply: Engine Carrier
