High engine temps- CCU? thermostat?
Im seeing higher than normal oil temps, my temp was normaly below the 9
o'clock postion but now its going past that and would even get close to 10 o'clock.
Found out that the oil cooler fan is not coming on even when engine temp is already nearing the 10'clock mark. Did the relay testing thing and fan works in both high and low speed so obviously the fan itself is OK and I guess I can assume the resistor is too. Swapped the oil cooler fan relay with the one from the A/C fan, oil cooler fan still not working, I guess that rules out the relay since the A/C fan works fine.
What could be wrong? The CCU? Thermostat? Forgot to check if the right fender gets hot when engine is at operating temperature.
Will be doing the manual fan override switch, but I would still like to have the oil cooler fan functioning automatically.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
There is a oil temp sensor located on top of the oil cooler. Just remove the RH headlight assy., and you'll see it there.
When this sensor fails, and is -open circuit-, the fan will run on -high- speed as a default. Doesnt seem like this sensor fails very often..
I am not certain exactly what sensor triggers fan operation. Anyone know?
Technical Guru
Originally Posted by tracke30m3
... close to 10 o'clock. ... The CCU? Thermostat? Forgot to check if the right fender gets hot when engine is at operating temperature.
Originally Posted by JasonAndreas
... I thought there was something related to actual vehicle speed but I can't find the source for that ... I can't find anything documenting the oil temperature required for the blower second stage.
Technical Guru
Originally Posted by DarrylH
I don't think there's any speed-dependent input to the CCU for the oil cooler operation (although it's a good idea...)
