Front tire rub - INSIDE - stock height/wheels...?
I did a search and found topics on tire rub after lowering, and concerns about rubbing the outside edge of tire on the fender, but with my stock height (I don't call it "SUV") and stock size 18" wheels/tires should it be possible to rub the inside edge of tire as shown in the attached photo ? It appears to happen on both sides when auto-crossing..... Ok, I know that about worse case in terms of tight cornering and suspension deflection but I did not think I should get the rubbing anyway..?
This is a question for a wheel expert. Not me.. but...
I can see a problem if you have aftermarket wheels with the wrong offsets. What is the rim offset? Stamped on the rim beside the air valve.
Good luck
Good luck
Hummm!
I checked the Maintenance manual and found no reference to your problem.
However, I found this quote in Adrian Streather's book on the 964. It may apply to the 993 also.
"... evidence of wheel rub can mean one or more of the following:
- Steering stops not corrrect for wheel and tire assemblies"
I deleted the first two coz they were eliminated by statements in your posts. You can do a search and see what you come up with... good luck.
That rub is nothing. Just from wide wheels and using full lock, which you only do at low speeds. You could set the steering stops to prevent this, but ignoring it is easier.
Big-Bro,
I could take a picture of my wheel well that looks exactly like this and for exactly the same situation- i.e., standard US ride height, standard factory 18-in rims, standard front tire (225/40), immediately following aggressive autocrossing. Oh, and I can guarantee that the original shocks were shot at the time.
I found that a realignment to RS specs helped (presumably more negative camber, but can't say what the original alignment was because I had just bought car). Last weekend I ran new front 235/40 MPSC's at an autocross and even with this wider tire did not see any evidence of rubbing. From what I could tell, it only happened at extreme lock, and even though it doesn't appear to be a problem any longer, I'd take hdemas' advice and ignore it. At least until it popped a tire and stranded me at an autocross...
-Paul
-Paul
RL Technical Advisor
Gentlemen:
That, dear friends is quite common and it occurs only at full lock with a wide tire.
Given the wide variations in sectional widths between tires or the same size but different brands, its hard to avoid with any car that has been lowered. I've seen that for 25+ years (since the introduction of 50-series tires).
One can prevent this with some custom steering rack limiters, but IMHO, its nothing to worry about. If I lived in the Salt-Belt, I'd be conscious about turning the wheel to full lock and I'd coat the bare metal with 3M Body Shutz.
Thanks for the replies guys !
I'll ignore for now - yes, that is the only time I notice it was after autocrosses, it just surprised me.
And yes, still stock height with stock shocks.
I bought the car 2 years ago with only 19K miles, but I just passed 29K miles and am putting more miles on quickly - couple of road trips scheduled for D.E. track days this season......so I am sure that I'll be doing the shocks "soon" and I'll start falling much further over the edge of the...slippery slope......
