RS side skirt installation help needed.
#31
Thanks Bill... I got it. Any chance you can find the porsche part number? I'm putting in the order for all the hardware through Pelican and it will save me a trip to the hardware store to have everything shipped together for the install. Any other words of wisdom (I did read your two pelican threads as well)? Looks like you applied some sort of paint or sealant after you drilled the holes (what did you use to prevent rust?). Thanks again.
#33
Thanks Bill... I've read both your install threads on Pelican. They were very helpful; in fact, I probably wouldn't even think about attempting the install myself without the excellent writeup. However, it doesn't show the part number that I'm looking for (#18 in the diagram below)
#34
I think I was able to find it (that is if it is the same part that is plastic rivet used to secure the plastic trim piece along the front of the trunk)
999-507-427-40-OEM PLASTIC RIVET or EXPANDER NUT 6.3 ($0.75)
#37
So, I finally got around to the install. I got tired of waiting for the last part (rear wheel well plate 993.504.481.00). Has been on back order for 2 months. So I created a poor-man solution, which turned out rather nicely.
Went to pep boys and bought a set of large truck mud flaps ($8). Used cardboard to create a template, and voi la. Not too shabby. Now on to the left side.
The following 2 users liked this post by ninjabones:
Matthew So (06-09-2022),
SpeedyC2 (04-15-2024)
#38
Dear All
I have had my 993 RS for 20 years now, and the clear stone guards on the front faces of the rear fenders have gone cloudy in appearance and have a matt finish (photos attached). The stone guards would probably benefit from being replaced.
My concern is that, as the RS sideskirts overlap the stone guards as shown in the photos, in order to effect the replacement I would need to loosen the rears of sideskirts to pull them temporarily away from the fenders.
I don't know how viable this is. All I read online (Rennlist and Pelican) suggest that there are some fragile tabs associated with the skirt mountings. I am reluctant to try replacing the stone guards if I am going to mess up the skirt attachments.
Has anyone faced a similar issue? Any guidance would be gratefully received.
Best wishes
Grogger
Best wishes
Grogger
#39
I would start by removing the screw that attaches the top of the skirt to the fender and see how much the skirt pulls away from the fender. There is also one lower which attaches to the fender liner and can be seen in your second photo, directly right of the big "N" in "MICHELIN".
Between those two, you likely do not have to undo any of the clips on the underside of the skirt. Should be enough room to work.
#40
I don't have the car at the house, but at the weekend I will remove all visible screws from the rear of the side skirt and see if I can gently pry the skirt away from the fender.
Cheers
Grogger
