Pss9 stiffness adjustment?
Just wanted to confirm twelve o' clock is the notch where the setting is (for rear shocks), but what about front shocks? I did a search on the topic but they are very confusing indeed.
winsome,
When I had PSS-9's, this is how I adjusted them:
To adjust shocks, turn **** counterclockwise to find stiffest setting (1) and then turn dial back, feeling for clicks. (+=stiffer) It might help to mark the spot on the shock body where the softest or stiffest setting is with a dab of paint.
winsome,
The dials aren't always installed well aligned with a reference point. Turn the dial clockwise or counterclockwise until it won't turn anymore and then you are at either 1 or 9. Then make a mark on the shock body to keep track of your setting.
Good luck
Skip
Good luck
Skip
At VIR this past weekend, I found that on one of my front shocks, there are no clicks. The dial does have the stop in either direction. My front shocks have a white line on the side of the barrel below the ****. The problem is you can't see this unless the car is up on a lift. Would have been nice if the fronts where adjustable from the top of the shock.
Todd
Todd
Originally Posted by Matt Vaughan
Mark,
FWIW, counter-clockwise is softer.
BTW, I have never lifted the car to adjust them. You can reach both fronts and rears easily lying on the ground. I just roll the adjuster from bump to bump and set them in the middle for street use. For track, rears on full hard, fronts in the middle.
Mark,
Guys,
I may have heard it incorrectly, but I called Steve Weiner a couple of years ago and I thought that's what he said. Maybe he said counter clockwise is softer and I got it all wrong. Sure wouldn't be the first time.
I guess if you run somewhere in the middle it doesn't really matter which way is softer/stiffer. If you run closer to either end it's very obvious, it's either pretty stiff or too soft.
I am blessed with the ability to know which way to screw in a light bulb, so I did not want to push it with PSS9. No disparagement intended for those whose intended use benefits from them, but this adjustment confusion is one of the reasons I went with what I have.
Mark was exactly right in his first post. Full counterclockwise is for the hardest setting. It's very easy to remember: just remember that it's exactly the opposite of what it should be. You'd think that "loosening" the thumbwheel would "loosen" the shocks but it's opposite.
Terry- you're absolutely right there's adjustment confusion. I've heard stories of people around here being found at track events with their suspension on full soft accidentally.
1=Stiff
9=Soft
German perception. Well, of course #1 is stiff, stiff is the starting point.
ToddB
If the *** is installed backwards there will be no clicks. The convex ball is on the ***. Take it off and check that it is installed properly. Of course there is no sound, just a feel.
PSS9s for the 996 have the *** on the top. Very easy.
9=Soft
ToddB
All - Mark in Balt was correct - counter-clockwise is stiff (1)
Randy - how easy is it to make that change because I don't think any of my dials have a click. Can I do it with the shock on the car and does it affect anything.
-Skip
-Skip
I could have sworn clockwise was stiffer. Each time I'm under the car I think of "tightening down" the suspension, as I cannot see while reaching under the car. I wonder if there are differences between those purchased in the U.S. vs. Europe? Mine were purchased from Gert in 2001 so they're older.
Skip. You do not need to remove the shocks, but you must lift the car. The fronts are on the very bottom of the shocktower and you need a visual and elbow room. I did mine on jack stands. You only need a very small allen wrench to operate the set screw.
