Plastic coated wheel socket
I've been looking around for a plastic coated wheel socket for weeks. Some recommend Snap On (AIS171) but it's discontinued now. Griots sells a set of 7 (3 metric, 4 std). My M Coupe uses a 17mm socket. Is the 993 also a 17mm?
Examples of what Bimmer people do
My brother has the 993 so I lurk here now to learn from all of you
Snap-on has/had a nice steel socket with a soft alloy liner that works pretty well with the 19mm alloy nuts. However, the bmw link above seems to indicate that they are NLA.
I polished up the outside of the socket with 400 grit on a drill so that it would minimize scratching on the deep rear turbo wheel lug nuts. Anyway, I recommend this $30 socket if you can find it.
It matters much less once you switch to steel lug nuts though. slip slip slip
Pete
Pete
Pete
Pete
Originally Posted by FisterD
Uh oh, is this an upgrade I haven't heard about yet. Steel Lugnuts? Is this true? I would think the alloy ones would better, ie;lighter...no?
I believe the track guys swap out the lugs to steel for strength.
socket
i know exactly what you mean. go to harbor freight and buy socket with aluminum insert very cheap!! then put plastic heat shrink on the outside. why dont they make a socket with protection for lug nuts and your wheels. dont know about manufactures sometimes. i think the 3 piece set is 15 dollars. can order of internet if not in your town. buy 3 set and give the others to a good friend that needs the bigger or smaller size
