993 Brakes
I have a 993 1997 Carerra 4 and am wondering if anybody can help as to what brakes are on my car - large silver calipers with drilled vented disks. The calipers and discs appear larger than Carerra 2 brakes.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The C4 model typically had silver painted calipers, which are the same as the standard issue black calipers found on the C2. C4S and TT had the red, larger calipers as standard.
Brakes
C4 has the normal 993/S4 caliper on 304x32mm rotors front and the small/basic 4 piston rear on 299x24mm rotors rear.
The C4S will have the Big Red on 322x32 front and a slightly different version of the 993/S4 caliper on 322x28mm rear rotors
