buying used bilstein hd - what to check? what should be included?
Dear all,
I found almost new bilstein hd on ebay and decided to buy them.
I am going to go and pick them up this weekend but was wondering if there was anything that I could check to make sure there isn't any issues with them.
In addition, I was wondering what I should be expecting in terms of parts included.
Thanks a lot,
Pierre
Thanks a lot,
Pierre
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I was watching that set on eBay. They dont look that old at all. Check the shock shafts for straightness as well as the shaft threads. Other than that, they should be fine..
If this is the auction you are referring to:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I would make sure they have the extra thread that allows for lowering the ride height to Euro/RS specs. Or, you can always purchase the lowering collars from Hergesheimer’s that was discussed here recently.
https://rennlist.com/forums/showthre...owering+collar
Also, the springs do not look like the RoW M030 springs that allows for lowered ride height as they have a yellow mark. If I remember correctly, when I installed my M030's, they had green and brown marks on them.
You should, however, be aware that changing just the springs will improve the ride (rebound and compression) only, for the most part. You may get a bit less body roll due to the increased stiffness of the HD's, but the ideal setup is to lower the car with the combination of HD's with extra thread AND upgraded sways. The aforementioned setup, with the bigger sways, really enables you to dial out a lot of the understeer that was dialed in (by design) at the factory and move towards more neutral handling characteristics. You can then adjust corner balancing and alignment for more oversteer if thats what you're looking for.
http://www.carnewal-europe.com/main.htm
Hope that helps, but rest assured; if you are replacing the stock Monroe crap that was on there, the HD's (alone) will be a VAST improvement over what you're used to.
Originally Posted by pierre_l
Dear all,
Thanks a lot,
Pierre
Thanks a lot,
Pierre
thanks for your answers, I will use eibachs springs that I already have.
anyone has a picture of the drop links mentioned (I am originally french and not sure what drop links mean...)?
Thanks,
Pierre
Thanks,
Pierre
Thanks,
Pierre
Thanks,
Pierre
It is the metal piece that links the rear shocks with the sway bar. Here is a pic of a similar one on a 914. On your HD's the link gets connected to the aluminum bracket that is on the rear shock.
Originally Posted by cabrio993
Make sure that they include the drop links for the rear sway bar. The stock drop link is different and you must use the one provided with the rear HD shocks.
If you buy HD's new, do the correct drop links come with them?
Thanks for the info.
Jeff - I'm not sure who you plan on ordering the the HD's from, but it does not look like Gert "includes" new/different drop links when you order JUST the Bilstein HD's:
http://www.carnewal-europe.com/cpx_p93089.htm
I'm sure he has them (droplinks) and his service/delivery time is outstanding, but I don't see why you need to change droplinks if you're only swapping shocks - especially if you already have the RoW M030 option.
Just got an e mail from Gert
I have HD's and HR springs being delivered on Monday from Gert...saw this
post and sent him off a note and he confirmed that the HD's he sells come with the droplinks.
Can't wait to loose the SUV ride height!
I just came back from the shop to pick up my car after H&R springs and HD's setup.
The ride is simply amazing! Night and day from my prvious setup. Ride Height is actually perfect for me. We made it 25" at rear and 25.25" at front. I had 24.75" at front before and it was rubbing some at the fenders on heavy compressed turns.
You won't regret it. This car rides as it should have from the factory now.
