clicking clutch
Hi Everyone:
I have had a clicking noise whenever the clutch was engaged. As a result of reading the archives I replaced the slave cylinder. That was last june. The noise stopped. Well, now its back again. Has anyone changed therir slave cylinder because of this clicking and had it return. If so what did you do. Do I need to replace the cylinder again. Thanks for your help.
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
I have only had the click once in the life of my car. It went away with a fluid flush, without replacing the slave cylinder. Did you replace the fluid when you changed the slave cylinder?
Tony,
Do a search on this - may take a while, since this has been discussed a lot. You've gone the traditional route (slave cylinder and flush), but one of the guys here recently solved this problem (and posted the results here) by lubricating the pivot and actuator points back where the slave cylinder is. I had my shop in Syracuse do this lubrication when my '97 was in for fall service (along with the annual slave bleed) and for the first time no "creaking clutch" !!
I actually printed off the forum thread (must have been this past summer?) and gave it to my shop for them to read and do the lube work.
Technical Guru
If your hearing a clicking sound (click-click-click) and not a "creaking" sound when you push the clutch pedal to the floor then chances are your release bearing and/or your pressure plate have partially failed.
Originally Posted by mike cap
Thank you, Mike. LOL... I don't remember the thread and I posted in it... boy am I getting old.
what about the "creaking" sound.... i sometimes get that and wrote it off as something that some wd40 or lithium grease would cure...appears to have more to do with the clutch PEDAL depressing, not the clutch itself...
Kelly:
Too much sun. No such problem here.
Sulley:
Creaking sound is what we're talking about. Sounds like an old screen door spring. The lubrication that my shop did with the car in the air did the trick.
Sulley:
