Random Misfire Diagnosis
Originally Posted by Eric86Red911
thanks for the pic JP
If someone needs pictures from another specific part, just ask!
Originally Posted by Lowblow
Had a similar experience with my car but it turned out to be the plug wires.
The insulation had broken down through the years. Man, those things are expensive..+/- $500
mike
mike
RL Technical Advisor
Mike;
I would surely check ALL of the HT cables before springing for coils.
You can do that with a spray bottle filled with water and then misted over all of the plug wires and coil wires in a dark area (with the engine running, of course). Increases in corona will show any electrical leakage and what needs replacement.
Thanks Steve, I will check that out! I know a couple of the HT cables are not in the best shape (the ones on the lower bank) so I will start with those. Too bad you can't order each cable separately....the upper ones look new.
Cheers,
Mike
Cheers,
Mike
Technical Guru
Cheers,
Mike
Cheers,
Mike
Have you checked the resistance of the ignition coils with a multimeter? Do you have access to an oscilloscope?
