uh oh -- is my car battery dead (?)
just got back in town after 5 days....went to garage....car wont unlock with the remote key unlock function.... the little red light is lit on the key, so I know it is sending a signal...
cant believe that I never thought about this happening, but how do I even get to the battery??!!!! Unless I am just being really dumb (always possible) I do not see a way into my car without the remote unlock function....
Can't you unlock the doors with the key manually.....via doorlocks? I believe there is a manual hood release in the left wheel arch...Hood Release Thread
Good Luck........I use a Die Hard battery maintainer for extended parking.......AK
Good Luck........AK
Good Luck........AK
The owners manual explains how to get in the car without the remote. But, the 4-digit code number on the key card must be used in the ignition switch to deactivate the burglar alarm. You have 100 seconds to enter the code before the alarm goes off.
i plan to get in the car manually (see if i can remove the bumper-plug type devices from the door handle, or use the manual trunk release)....
are you saying that i will need a special "key card" once i get in the car (?).... with no battery juice, i dont expect the alarm to go off at all...so are you talking about once i get it started again ?
what a mess...will definitely not make this mistake again, time to purchase the Optima battery and a trickle charger..
I think jla3317 is refering to deactivating the immobilizer if you have a failed remote and use the key to unlock the door. But it sounds like your remote is fine...and your battery is dead...and you have no outer keyhole (?)....never the less....it is explained here I think....scroll down
Key Entry
AK
Key Entry
AK
thanks for all the help guys....
its a little ridiculous when 4 days away results in this.... but such is life i suppose....
would have hardly considered 4 days "extended non-use", but I guess so.... will definitely remedy this with a better battery and a trickle charger for when I will be away from the car for more than 36 hours... :-)
thanks again
thanks again
Make sure you use a battery 'maintainer' (turns on/off depending on battery charged or not).....not a battery charger (continuous charging) for storage. If your battery died after 5 days....it likely needs to be replaced or you have an electrical drain somewhere....but I am sure you realized all this! Good luck....AK
