Suspect your Varioram not working? It could be ...
#31
Originally Posted by Martin S.
I would think this would be negative pressure and tend to pull the tubing flat.
I'd probably try that before bothering to order a new part...
#32
Wouldn't the insertion of anything into the tube restrict airflow ? As this tube contracts and releases, the natural tendency of the rubber would be to collapse over time. Especially with as many times we take these babies into Varioram Territory
Putting anything in the tube would have the same effect as plugging a straw with a spit ball.......basically causing the same pressure problem as a restricted or collapsed tube......no ?
#33
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
I don't think there is any airflow through the tube...just negative pressure from ambiant. Once the engine pulls the vaccuum, the flow stops. I would think a coil spring of the appropriate size would hold the rubber in the right shape and stay in place.
I will have to check mine out but I think it is working OK. I test the varioram every time I drive the car as I love the sound!
Wonder what my wife will say when I tell her that I have to check the thingy to see if it has collapsed!!!! ARR, ARR
#34
a very fine shunt material would provide little restriction...
IMHO, or, some clever chap willl make up a part out of stainless, or, if there is any market for this. I have to go into Newport Auto Center, Newport Beach, CA later this week. There resides a Master Wrench, Kevin Kelly, formerly a lead mechanic at ANDIAL. I will show him the part and solicit his opinion...and post accordingly. Until then.......................... I'll be laying low!
#35
#36
Today's fix...
I had an opportunity to fix this today. My solution... a section of 13/32" hard brass tube cut to length to fit on the inside of the tube between the two nipples.
Sorry for the bad pics, but in the foreground you can see the small section of the cut tube.
Then carefully install the brass section into the inside of the tube. Make sure to not cover over the holes leading to the attaching tubes. The brass part is the shiny thing inside the tube... again, sorry about the focus thing.
Once installed, the tube has a very slight pregnant look. It's actually held in place reasonably well, so I don't think it's going to move. If it did move the worst that happens is that a hole is covered up... the brass section can't leave the tube as it's larger than the attaching tubes in all directions.
It's raining here, so I don't have any way to test it. I'll post again when I get a chance to test it.
#38
Kelly,
I'd be more than happy to cut a bunch, but it may be just as easy to go to any hobby shop to purchase the hard brass tubing. Once you cut off the small section you can use the rest of the tube to push the short section in to the right depth.
I can cut off a short section for as many that want them (send me a PM with address), but you'll have to find a tool to push it into the rubber tube.
#39
Nice little fix...thanks for the insight. This should be the end of this thread. We had a problem, and now we have a solution.
As Chris W. says, "Is this a great place, or what?"
#40
Thanks Martin, great post.This may be the answer to all my current running problems! I'm suffering from strangled engine syndrome of some sort, under load, heavy acceleration etc. blah blah...... I'll try it tomorrow......thanks again
#42
Martin-
Thanks for the post. This is exactly why I'm addicted to Rennlist. I think I'll just add this part to the "replace every 5 year" list.
With my luck I'll try to rig a more permanent solution and have the foreign parts get sucked into my engine!!!
Has anyone gotten a price for this piece yet?
Mike
Mike
#43
Has anybody checked theirs and it wasn't collpased?
Mine sure is, I'll probably do the brass tube fix as well, just curious if
there are any out there that don't at least look collapsed?
#44
Originally Posted by lowblow
Martin-
Mike
Mike
Lastly, if you use the 13/32" OD hard brass tubing it is snug on the inside of the tube... it's not going anywhere anyway.
Ciao!
#45
Well, mine is not collapsed..but then it has been 3 almost 4 weeks sinse I drove it. That could be enough time for it to lose the vaccuum that it had when driven. I do know the varioram does work as it lets out a howl at 5000 rpm. Don't know the next chance I will get to drive it...last time was the Drivers Skills day up here with the NW PCA. I will have to find some time between work and holiday stuff and weather!
Ciao
Ciao
