I now need new front tires, but have 1/2 worn S02s in the rear. Does anyone see a problem with putting S02As in the front until the rears go away? I actually could use the extra width with these wheel widths.
Front- 225-40-18 on 9 inch wheels
Rear - 285-30-18 on 11 inch wheels
(I did search the archives, but didn't see an answer to this Q)
While not ideal it's probably OK as the tread patterns are similar....I will have to make a similar decision when my rear SO2s wear out. btw, if your car is a 2S you may want to consider increasing the front to 235 or 245.
