993 Forum 1995-1998
* ? re 3.6 engine - hot engine/performance
Old Nov 8, 2004 | 12:01 PM
TrackDays247.com's Avatar
TrackDays247.com
Former Vendor
Question * ? re 3.6 engine - hot engine/performance
Have a 330hp 1997 Varioram 3.6 in the 79SC.
What system(s) are on the 993 engine with regards to:
Oil temp
Cylinder/engine case temp
I need some specific 993 engine system details that might explain a performance change based upon oil & or engine temperatures.
Ideas?
Thanks a ton!,
Craig
Old Nov 8, 2004 | 12:21 PM
FlyYellow's Avatar
FlyYellow
Craig,
What makes you think that you have a 330hp motor. They came with 282 at the crank. I'm curious if this is a real number and if yes what was done with the motor...
As for oil temp. The 993 has a rather large oil cooler located in the front right area behind the headlight. The 993 oil cooling system is even somewhat inadequate and many have installed auxillary oil coolers on the driver's side with the appropriate plumbing.
I'm sure someone here has a detailed design. If you'd like i can scan in the shop manual diagram.
Cheers,
Boris
Old Nov 8, 2004 | 12:27 PM
TrackDays247.com
Former Vendor
Well, what makes me think that I have the HP is this:
RS 3.8 cams
Steve Weiner ECU optimized for 96 octane
**280.5 hp/247 tq to the wheels on Dynojet 248C**
What I need is someone that is able to tell what system(s) dials back timing etc based on oil or cylinder temp.
This is installed in a 79SC with 2 oil coolers that need repositioning for better cooling.
Old Nov 8, 2004 | 12:28 PM
garychios's Avatar
garychios
Does your car feel slower when it warms up? Mine does to? Cant figure it out.
Old Nov 8, 2004 | 12:45 PM
TrackDays247.com
Former Vendor
It does! Oil temps of above 210 it feels slower.
This engine is in a 2500 lb 1979 911SC chassis ;-)
Essentially a street legal race car with all the changes I have made -
Ideas???
Old Nov 8, 2004 | 02:25 PM
tvurt's Avatar
tvurt
Have you looked at air intake temps? Some of the aftermarket cone filters decrease HP by increasing the air temp to the engine. See the p-car diy on the intake temp!
Tom
Old Nov 8, 2004 | 02:29 PM
993RS's Avatar
993RS
RS 3.8 cams
Sorry, but ask Steve W.: no way you can have 330 hp with just those two mods. And I do not trust dynos either... IMHO: you need to do a "before mod " and "after mod" dyno with the same dyno and the same dyno parameters to see what improvement resulted.
Old Nov 8, 2004 | 02:33 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
RS 3.8 cams
I am not certain timing is controlled by oil temperature, more from knock detection. Give Steve Weiner a call, he has the answers you are looking for.
I must say that those HP numbers are pretty impressive. Thats about a 60hp increase for reading at the wheels, compared to typical 993 dyno results..
Old Nov 8, 2004 | 03:25 PM
TrackDays247.com
Former Vendor
"Sorry, but ask Steve W.: no way you can have 330 hp with just those two mods. And I do not trust dynos either... IMHO: you need to do a "before mod " and "after mod" dyno with the same dyno and the same dyno parameters to see what improvement resulted."
They are REAL numbers. This entire project was coordinated with Steve Weiner.
All parts and software purchased from Steve Weiner.
Dyno sheet worked on and analyzed by Steve Weiner.
Ran on a dynojet 248C used by about 50 other Porsche racers in the Seattle area.
Virtually the same conditions (humid, Seattle weather).
Indeed they are real.
My signature line from the PelicanParts discussion list:
Euro 79SC no options/3.6 Varioram/3.8 RS cams/Ti retainers Aase springs/Weiner ECU/B&B headers/Flowmaster/330 hp & 292 tq/WEVO-ized/Recaro PP
So there are many other mods.
End result: 330hp/291tq accounting for 15% loss.
Air intake temps are ambient, BTW - measured them. Was pretty happy with this.
Took the stock cover, installed it in a jig, bandsawed most of it off, leaving only a 1/2" lip.
Old Nov 8, 2004 | 05:35 PM
akolodesh's Avatar
akolodesh
RSRS -
Sounds like a pretty awesome ride - would love to see a pic or two of that monster!!
Old Nov 8, 2004 | 06:06 PM
TrackDays247.com
Former Vendor
Its a little ugly right now - until the hole-sawed front bumper gives way to the RUF F&R bumpers and a front repaint.
The underpinnings are top rate though
Here are some pics from awhile back -
Old Nov 8, 2004 | 06:16 PM
akolodesh's Avatar
akolodesh
thanks... I bet its a rocket
Old Nov 8, 2004 | 06:18 PM
TrackDays247.com
Former Vendor
It is. A loud, rough, track rocket!
THX
Old Nov 8, 2004 | 09:35 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Craig:
A few things to note,.....
1) Power does drop off precipitously in 911 engines when oil temps exceed 210 deg F. Its been that way since 1966,.... One does what one must do to keep oil temps below that for maximum performance and that includes properly installed dual oil coolers.
2) These knock-sensored engines are adaptive. They cannot however, restore lost power when the oil and cylinder head temps get too high. They will supress incipient detonation at high operating temps by retarding ignition timing to suit and thats part of what you feel when the engine gets hot.
Get those oil temps down to 185-190 deg F and it will run stronger (and last longer).
P.S. I never compare or extrapolate rear wheel HP figures with HP at the flywheel. There are FAR too many variables to make any accurate predictions and it simply comes conjecture and tavern talk,.... RWP is just that; Rear Wheel Power.
Old Nov 8, 2004 | 10:02 PM
TrackDays247.com
Former Vendor
"P.S. I never compare or extrapolate rear wheel HP figures with HP at the flywheel. There are FAR too many variables to make any accurate predictions and it simply comes conjecture and tavern talk,.... RWP is just that; Rear Wheel Power."
Yup I agree - and that is why I ONLY refer to HP comparisons when using:
Same dyno (Dynojet 248C)
Same location - Totem Lake area of Kirkland
Nearly the same conditions (easy to do here in the Seattle area) *&* corrected numbers
Then we are just about in the same ballpark. Without that.......well, its all a bunch o' hooey isn't it?
