Supercharged 993 on the track
Hi all,
I have a '95 993 C2 which I use mainly for track days (DE events) here in the UK. It has been upgraded with PSS9's RS sway bars, strut brace and Michelin Cup sports. (as well as other mods such as RSR's and internal trim items etc) I have also just bought TT big reds for the front and am awaiting a set of RS big red calipers for the rear from Gert.
It has done 73K miles and runs really well on the track, but as allways I yearn for more, especially to deal with the GT3's
So I have also just bought a TPC supercharger kit which is in a box in my garage awaiting fitment (winter project)
Boy is that slope slippery!!!!!
My question is will I blow up the engine if i use it on the track? What about the gearbox and differential, drive train etc will it take the strain?
Should I put on an extra oil cooler?
What should I do to minimise the potential risk of overstressing the car given track use?
At the moment I don't plan an intercooler.
Have searched the archives but they don't give a lot of clues as to track use?
TIA
John S.
TIA
John S.
If you run on the track, You should add a Cargraphic oil cooler even if you don't have a supercharger.
And, if it were my car I was tracking, I would add an intercooler to the S/C. That extra heat is not doing your pistons or combustion chamber any favors.
John,
Also there seem to be differing opinions as to whether or not changing the engine compression is needed. Sachin did not change his and is comfortable with it, others (Steve W. for example) recommended lowering the compression to deal with the boost. I suppose only long term use will tell which is correct. Obviously I would love to find out that SC our cars without changing the compression won't affect the engine long term - that would save a great deal of cash on a terrific mod. Either way, I think spending the couple grand more on an intercooler is definitely the way to go with this mod.
Sent you a PM as well.
Congrats on your decision to SC your car. You will be amazed at the difference.
In regards to track use. I'm just getting started myself. Although here's a list of things you MUST address regardless of Track use, in order of priority.
1) Ignition system - Replace everything. Plugs, Wires, Distributors & Rotors, and Ignition Coils or you will experience random misfires. The SC just amplifies everything.
2) Intercooler. Mine was custom. I can send you details. Hot Intake air is not good.
3) Oil Cooler - I don't have one, but if you are considering track use its a must, especially if you don't have an intercooler.
4) Not sure if u have a C4S, but beef up your brakes. I was fortunate to start with a C4S which had the big reds.
Good Luck, and let me know if I can help in any other way.
EDIT:
I'm not sure what impact the SC will have on the drivetrain. I know I'm a bit more carefull with my shifts now. I feel confident that my drivetrain can handle it since my C4S is AWD which is the same as the TT AWD (I think)
EDIT:
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
More HP= more heat.. Add oil cooling capacity at a minimum.. Sounds like a fun project....for a rainy, cloudy day
Chris, 360 Hp + 40% more torque through two wheel drive on the track - Hmmmm not sure if a rainy day would be a good idea.
More seriously I need something to do this rainy winter in the UK. Last winter it was PSS9's, roll bars, strut brace, RS motor mounts ... etc
Thanks for all the advice guys, oil cooler is a must, luckily I dont have air con so have a nice space in the left wing and also for fan, relay in the fuse box etc.
Any ideas on fitting a stock set up from the right in the left where the air con would normally go?
Or what about a standard oil cooler core since I have space? Do i really need to go cargraphic?
Do i really need an intercooler? Surely an additional oil cooler will suffice?
John.
P.S. Yesterday my wife asked as I was off to work if she could put the box of "rubbish" in the corner of the garage out for the trash men, when I told her no as it contained £4000 of supercharger kit she was not happy!!! I had only got permission for an upgrade (vague) of an unspecified amount! I had to leave very quickly for work.
When I got home the spare room was full of new clothes, shoes etc "for the winter" - " well if you can spend that much on your car........." - why don't they understand!
John.
cheers, Maurice
