Syncro replacement cost?
There has been talk about fluid changes to fix the problem of a slight grind in second gear when cold. Does anyone know what it would cost to fix it properly with new syncros for second (also 1 and 3 maybe since the tranny will already be out)?
I am wondering the same as well. To get around the grinding I have resorted to double-clutching second gear the first few minutes in the morning.
What tranny fluid is recommended? I used Redline MTF in my previous car (M3).
I think I read somewhere that the second gear synchro is pretty expensive compared to the others. I could be completely wrong though. Something about it being two piece? That may only apply to the steel synchros though, if I am right at all.
Wow, and I thought this problem was just me!
I had this work done very soon after I bought my car two years ago, but my records are at home. I'll track down the records and post later.
I had both 1st and 2nd synchros replaced, then when it continued popping out of 2nd gear, went back and had 1st and 2nd gear replaced. However, after all that work, on cold mornings my car will still clunk or mildly grind into 2nd. What seems to work best for me, believe it or not, is to shift faster. From 1st, I put it in neutral, rev match, then quickly yet still gently put it in 2nd. The two finger method works for me (use only two fingers on the shifter, so as not to give much force into gear. I've read here others do the same.) If I take my time about putting it into 2nd, it will invariably grind.
I hope that helps. I'll look for my records tonight.
It's pretty common for a mild grind on the 1st to 2nd shift when cold. This has been discussed many times over the few years I've been on the board. Some people have noted some change/improvement with different gears oil brands, but none that consitently eliminates the grind. The second gear synchro in steel is expensive (about $1500), but I do not know the price of the brass version (brass for street, steel for track). In any case it means dropping the transmission and pulling it apart which is likely to be over $1000 in labor.
It's an expensive proposition for a fix that is unlikely to fix the issue. I've had my transmission regeared (shorter gears and new synchros) and it still happens. It's a design issue that I would not worry about if it is limited to a mild grind only when cold - you are not causing undue damage to your transmission.
In other cars, when the tranny is rebuilt and still grinds, sometimes the step of the flywheel is off or the clutch is warped or worn. Also the pedal travel needs adjustment or the system cables or clutch slave need bleeding. This is what I do on my Mitsu race cars and I run passed the 9500 RPM mark which kills synchros. I am sure some tweaking is also required on Porsches.
Mayb Viper Bob can chime in on clutch pedal adjustment.
Trackjunke - I replaced 1st syncro, 2nd syncro and cone ring, guide sleeves for 1 and 2, and gaskets. Parts were $500, labor $1500, for a total of $2000. Four months later I replaced the 2nd gear set which includes 1st gear as well (it's all one piece). Parts were $1600, labor I got a break since it was not fixed initially. So grand total is in the range of $3500 to replace 1st and 2nd gear including syncros.
I think my tranny was abused by the PO, thus the major problems I had. My symptoms included 2nd grinding regardless of outside temps, and popping out of gear when decelerating. I do not think my experience is typical. But even with these repairs, in cold weather mine will still make a slight grind into 2nd.
Let me if you would like more details.
I need to get my fluid changed but I have trouble shifting from 3 to 2 at the track sometimes. It's almost like I overshoot the gate and go left enough to where you would engage reverse. It's a little disturbing but I usually end up getting it into the right gear eventually and keep going.
Lifetime Member
Lifetime Member
Good luck.
Adrienne,
Thanks for the prices. I dont seem to have problems downshifting even when cold. Just a slight grind when cold. I guess there is not point in fixing it until it gets worse.
